My final setup (need comments)
Old May 9, 2003 | 12:27 AM
stone89ROC's Avatar
Car: for now my Jeep while im building my Camaro
Engine: building a 350 with about 440HP and 450lb
Transmission: W.C. T-5 dont know how it will hold up..
ok heres my final decision on my stereo system setup
1. Alpine CD/MP3 player CDA-9811
2. 4x6's alpine SPS-460A
3. 6x9's alpine SPR-694A
4. 2 AMPs one for each sub JBL BP600.1
5. 12" HE 2 R Fosgate subs 4ohm
6. AMP JBL for speakers JBL P80.4
my questions.
1. can i run all 3 amps
2. how will i supply enuf power should i upgrade my alternator to a 140amp or go to an Optima battery
I need feedback
Old May 9, 2003 | 01:01 AM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
first off, make sure you upgrade all the wiring under the hood (everything that touches the battery, alt, ground, etc) with at least 4ga. if you still have probs, upgrade the alt like you were thinking. with class d's, i dont imagine you should have too many problems.
Old May 9, 2003 | 10:07 AM
White Ninja's Avatar
i wouldn't waste money on 2 seperate JBL amps...go with the 1200.1 and wire them parallel, 2ohms, 1200 watts.... saves you some coin, too.
- Andy
Old May 9, 2003 | 06:29 PM
9177's Avatar
Even with the 600.1 if the are svc 4 ohm subs you would only need one amp as the jbl is 2 ohm stable, Actully one I think
Old May 10, 2003 | 01:42 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I have heard that as well, although it's not a published spec. The other thing to consider is that the JBL amps are underrated, so the 600.1 puts out somewhere in the 700s and the 1200.1 at like 1400. I ended up ordering the DVC version of my subs so that I could run it at a total of 4 ohms cause I was already gonna have to keep my 600.1 turned way down at 2 ohms to begin with, not to mention any underrating to the figures from JBL.
Old May 11, 2003 | 04:17 AM
onebadwagon's Avatar
i doubt jbl underrates those amps for the price they charge, unless they get into alot of harmonic distortion at high volumes.
just my .02c
adam
Old May 11, 2003 | 07:42 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
actually jbl does underrate this line of amps . the 1200.1 is known for benching at 1400w instead of the listed 1200w. these are the best low budget sub amps and can compete with some of the more costly ones as well. i highly recommend this series to anyone who wants great amps for a low price
Old May 11, 2003 | 10:24 PM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
I definetly think that JL's are great! I use to have 2 10' JL and a D1000 american base amp and the subs sounds unreal... besides Audiobond i think JL is deftinly second on my list atleast!
Bubbajones_ya
Jul 6, 2024 08:32 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
