how do i attach power to my battery
Old Feb 15, 2004 | 07:07 PM
souperman28's Avatar
Car: 89 IROC-Z
ok well my battery is a side mounting one. so how do i rig something in there to get power to my amp? sorry guys its hard to explain. can i see a picture of somebodys in there car like the battery hook up? if you could that would be great!
Garrett
Old Feb 15, 2004 | 07:18 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
yeah i have those damn side posts too...please any help would be appreciated!
Old Feb 15, 2004 | 07:20 PM
CorVM's Avatar
Car: '92 Pontiac Firebird
Engine: LO3 305ci.
I just used a ring terminal and put it in between the main battery and power cable. Hope that helps, might not be exactly what you were talking about, but I can go take a picture if that would help any.
Corey
Old Feb 15, 2004 | 07:28 PM
Car: 89 IROC-Z
yeah it would be great if you could take a picture of it that would help alot because im not quite sure what your talking about?
Garrett
Old Feb 15, 2004 | 07:39 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
they have a replacement bolt that replaces the one that you screw into your battery. It had a nut on the end so you can mount your amp or whatever wire to. ill try to find a pic of it..Pepboys sells it i remember seeing it there.
Old Feb 15, 2004 | 07:41 PM
br()bert's Avatar
Car: 85 firebird
here ya go http://www.sounddomain.com/sku/LITSMB1L
Old Feb 15, 2004 | 07:42 PM
CorVM's Avatar
Engine: LO3 305ci.
Hope this is what you were talking about and helps some...
Here's the battery with the side posts. The black wire loom with the purple connector at the end is my amp power wire. It has a ring connector on the end.
Old Feb 15, 2004 | 07:45 PM
br()bert's Avatar
Car: 85 firebird
If you do it this way you can strip out the lead threads in your battery.,If you use the connecter in the link i posted the top bolt uscrews so you can add the ring for the amp wire without unscrewing it from the battery.
makes it look cleaner too.
Old Feb 15, 2004 | 08:58 PM
Car: 89 IROC-Z
well i went out to my car to try it with the ring and i couldnt screw it in. so i guess im gonna order that part
thanks,
Garrett
Old Feb 16, 2004 | 07:12 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
go to your local wal mart or auto parts store car audio store or anything like that. Ive got one that you screw it on. Then theres another bolt on the other end of it you screw off and attach the wire (with the hoop attachment.) to. Its not really worth ordering because you might strip it like I did and have to order it again.
Nate
I can take pix if need of my hoop attached to the wire and the bolt that goes onto the battery.
Old Feb 16, 2004 | 11:25 AM
Car: 89 IROC-Z
yeah all the pictures i can get will be great, i just need to see everybodys ideas
Old Feb 16, 2004 | 01:07 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
that is exactly what i used. those side posts were driving me nuts, so I switched to an omptima battery
Old Feb 17, 2004 | 04:52 PM
demicon's Avatar
Car: 89 Firebird
Engine: 2.8 MPFI
I knew right away I would have to deal with them damned side posts. So I solved things right away.
I bought a nice 800CCA (1000CA) battery with both kinds of posts. Never had a problem.
Now I enjoy laughing at those with only the side posts.
That was until I installed a stereo in my friend's camaro.
He had only side posts. I had to face my own mockery.
LOL.
It got done.
Old Feb 19, 2004 | 12:25 AM
Car: 89 IROC-Z
i would love to buy another battery but my battery i have now is only 3 months old and i couldnt go but another their to much money.
Old Feb 19, 2004 | 05:53 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I definitely second that!! After having to disconnect the battery enough times I went and bought one of those extentions too!
Previously mine was wired like the picture from CorVM... it was a TOTAL pain!!
BRoss99
Aug 10, 2025 05:08 PM
Bert87
Aug 23, 2015 03:50 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 13, 2015 12:59 PM
