Bose kicks
Old Jul 11, 2004 | 09:04 PM
Tonyrodz's Avatar
Transmission: auto
Bose kicks
I have a set of Bose kick panels and I don't have the Bose setup.
Is there a way to make them work as a reg set of speakers? Or is there a way to gut them and put some components in there?
Old Jul 12, 2004 | 01:55 AM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
hmm.... good question
Old Jul 12, 2004 | 09:53 AM
jdrafke's Avatar
I believe you need to have the bose deck along with the amplifier for the speakers to work properly. They are a self amplified speaker so they will not work with a regular cd deck. I had the bose kick panels in an older iroc-z and me and a buddy were able to modify them to fit 5 1/2 infinity kappa components. Theres a guy on this board with the name Todd91Z or something like that cant remember the exact nameand he helped me out quite a bit.
Old Jul 12, 2004 | 03:01 PM
Tonyrodz's Avatar
Transmission: auto
So it is possible to just gut them and use other speakers then? Kind of a shame to do--but since I don't have a Bose setup I think I'll mess w/it sometime soon.
Old Jul 12, 2004 | 04:45 PM
DVL86's Avatar
Car: 85 Iroc-z
Engine: 5.0 V-8
If you dont have a Boss stereo that came with the car then I highly doubt you will be able to use the speakers. You could try selling them on e-bay!
Old Jul 12, 2004 | 06:22 PM
Tonyrodz's Avatar
Transmission: auto
Well--they're cheaper then having a custom set of kicks, and I already have them--so I guess I'll have to gut them and put components in there--unless someone would want to swap?
Old Jul 12, 2004 | 06:23 PM
Tonyrodz's Avatar
Transmission: auto
other side..
Old Jul 12, 2004 | 10:09 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Get some wood and used the bose as a template to make your own.
Old Jul 18, 2004 | 05:58 PM
Tonyrodz's Avatar
Transmission: auto
Anyone want to swap for some custom kicks?
Old Jul 25, 2004 | 01:13 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
I don't see why you can't use those speakers with any stereo setup... if they are self-amplified, then that just makes it easier... I bet its high-level inputs! or if not, then I'm sure its just rca voltage input...
what you should do is look at the connectors, and find out which one's power, and ground, then the other two are for the actual sound... also, if you plan on gutting these things, you might be able to use the built-in amps with your new speakers... but watch out, because hq stuff like bose, and the monsoon system use something wicked like 8ohms.... maybe you could just replace the bose speakers with the bose replacement speakers?
-Steve
Old Jul 25, 2004 | 04:21 PM
Tonyrodz's Avatar
Transmission: auto
They make replacement non amped speakers?
Does anyone know the size speakers in these? I haven't played w/them yet--haven't really had the time. I'm not even sure if I got the other ends of the plugs for them yet!
Old Jul 25, 2004 | 11:58 PM
dpav's Avatar
You can cut out the self-amp and just wire the kick speakers to an aftermarket stero...my dad did that to my Sisters 89 maxima. They sounded sweet!
Old Jul 26, 2004 | 02:40 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
I just picked up a pair of these and discovered someone had already bypassed the internal amp. Reconnected the internal amp and yikes.. friggin things get way too loud with a decent stereo setup with the internal amplifier, and there's no gain control I can see on that thing. The internal amps are laying in a pile o' stuff now... the kicks are going in with the stock speaker directly wired. Very-doable, and personally good stereo equipment is better than the bose amp, even with its built-in crossover.
Old Jul 27, 2004 | 04:36 AM
ScrapMaker's Avatar
what a shame... I bet there is some way to lower the volume... bose makes some good amps/speakers
-Steve
Old Aug 3, 2004 | 12:53 PM
TechSmurf's Avatar
Engine: LS1, Scrap
I'm sure with a little work a variable resistor could be wired in to handle gain control on the bose amps, but personally I had two spare channels to play with remaining on my amp rack anyway... all full now tho. The bose kicks sound... okay. Seem a little flat.. seriously considering fresh speakers for them. Definitely filled the acoustic void under the dash line, though
Old Aug 8, 2004 | 10:35 PM
ScrapMaker's Avatar
hrm, is there anything spectacular about the bose kicks...? is it just the speakers, or are they ported or what?
Old Aug 10, 2004 | 12:51 AM
Yep, tuned port
Old Aug 10, 2004 | 06:52 PM
ScrapMaker's Avatar
oh man... if you could find the equivalent bose replacement speakers, that would kick some serious ***.... ported kicks... mmmm that gives me ideas...
I wonder if porting kicks would sound good for other speakers...
junior419
Apr 7, 2025 11:35 AM
1992Z28!
Nov 19, 2015 07:33 AM
Giocio
Oct 1, 2015 12:20 PM
tattmann
Sep 27, 2015 05:20 PM
scottmoyer
Sep 7, 2015 07:06 PM
