alternate speaker mount locations
Old Apr 6, 2005 | 11:52 PM
luke4907's Avatar
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
This is probably a stupid question, but is there room to mount speakers right behind the rear seat armrests? I'm talkin about the part that's curved (probably just is the wheel well and has no room underneath for any speakers).
Basically, I'm not into huge bass or anything. I have some Kenwood 4-way 6*9s and some good (forget what brand) 4*6s in the front, along with a bazooka tube with some other speaker in it, which sounds pretty good. It's just not balanced out very well and I don't have any eq or anything like that. Any advice as to where to install a mid-size speaker to generate some more lower-midrange volume? I'll have to look into the kick-panel pods everyone does around here, but I was just looking for suggestions. Thanks in advance
Old Apr 7, 2005 | 12:31 AM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I once saw some hideous boxes attached to the doors of a TA in a used car lot.; Maybe you could get it to look good. Or get an eq. Oh, hey, what about doing something with that wasted space in the passenger side of the dash, on the bottom, where there should be a glove box?
Old Apr 7, 2005 | 01:14 AM
luke4907's Avatar
Engine: TPI350
i get ur point... I don't like the idea of mounting an EQ somewhere that I won't even be able to reach it easily (even though I won't need to change it much once it's mounted and set) .. maybe I could do something in the center console, depending on the size of an EQ... I suppose I'm just a little concerned with blowing my 4*6s and I just want something to help them out a little bit. then again I should re-wire everything so that I could fade the rear speakers to be louder
Old Apr 7, 2005 | 05:26 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
the stocl locations for the speakers i find is horrible for midbass.... if anything i'd spend the money for the EQ on some components and put em in kickpanels.. it really is the easiest way to me
Old Apr 7, 2005 | 08:57 AM
305q_ta86's Avatar
Transmission: 5 spd
Check this out. My setup...
Old Apr 7, 2005 | 10:15 AM
luke4907's Avatar
Engine: TPI350
looks like kickpanels are the way to go... thanks for the input
clean looking installation there.. my headunit is a fullsize unit so no room for an EQ =\
Old Apr 8, 2005 | 12:35 AM
305q_ta86's Avatar
Transmission: 5 spd
Oh, ok. Just a suggestion. Kickpanels, I agree.
Old Apr 9, 2005 | 02:48 AM
ScrapMaker's Avatar
Car: 2000 Trans Am WS6 (Black)
who needs an EQ when most decks have them built-in?
I don't want to attract thieves, and I'm assuming there is not a removable face-plate for your EQ.
one thing to keep in mind, is on the newer camaros with monsoon setup... they put out as much deep bass as a pair of 10" woofers (they lack in the bass-hit area... but the actual tonal reproduction is amazing)
they do all this with two 4" woofers right above the rear seat armrests...
I looked as hard as I could, and there was no porthole, straight up sailpanel-style like in our cars...
if you can get a badass midbass driver, you could mount them there, and get some good response...
but maybe you'd be better off putting real components in the sail panel area?
Old Apr 9, 2005 | 02:53 AM
luke4907's Avatar
Engine: TPI350
yeah I'll have to look into that as well, but first I think I just need to rewire my system so that I can fade the front and back, screw around with the high-pass filters and the 3-band EQ on the headunit. and honestly these cars are so easy to break into (esp with my headunit just sitting in place currently) I'm not in the least bit worried of putting something else in that will persuade someone to break into my car...
Old Apr 9, 2005 | 03:13 AM
ScrapMaker's Avatar
so you say these cars are very easy to break into, and you aren't worried about further enticing someone to break in and steal everything?
I think someone hacked into your keyboard.
Old Apr 9, 2005 | 12:48 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
lol.... well i kno that when i locked my keys in my car. i couldnt jimmy the doors so i was fishing for the keys via hanger.
now the tint on my car makes it imposible to see into the car at all so i dont have to worry bout that
Old Apr 9, 2005 | 01:25 PM
luke4907's Avatar
Engine: TPI350
don't get me wrong, I don't WANT someone to break in and steal my radio, sub, amps, or t-tops or anything else, but i just don't think installing an EQ would be the deciding factor as to whether or not someone would break into my car.
here's a few ways I've broken into mine: 1) pulling the window back to reach my hand inside to hit the unlock button, 2) pulling my window back to unlock the t-tops, and 3) slim jim down along the windowby the lock (easiest of the 3 if you ask me)
damn I really need to install an alarm... haha
Old Apr 9, 2005 | 03:56 PM
305q_ta86's Avatar
Transmission: 5 spd
My eq doesnt come out, but between me living in a nice place, and all that stereo equipment being like 6 years old, I'm not worried.
Old Apr 9, 2005 | 10:10 PM
ScrapMaker's Avatar
FYI luke... it should NOT be possible to move your window that much to reach your hand in there...
for me I had to use a long hanger to push the trunk button....
now I just keep an extra door key in my wallet
Old Apr 9, 2005 | 10:36 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
me too
Old Apr 10, 2005 | 01:52 AM
luke4907's Avatar
Engine: TPI350
well that time it was partially open in the first place... and I probably was another inch from the glass just snaping on me..
Old Apr 10, 2005 | 02:31 PM
ScrapMaker's Avatar
Incredible Hulk, eh?
you shouldn't be able to move it very much at all...
lesson learned, don't leave your windows down.
Old Apr 10, 2005 | 04:13 PM
luke4907's Avatar
Engine: TPI350
not hulk, I used a crobar (very gently) wrapped in rags so it wouldn't scratch with one hand and slipped my other inside. I was 100 something miles from home and I didn't want to call for help in front of my g/f and all her family.. I felt like enough of an idiot that I got locked outta my car at their house... I figured worst case I'll have to drive home without a window and rip out one from my friend's car I'm parting.
someday I hope I'll learn...
Old Apr 10, 2005 | 09:48 PM
ScrapMaker's Avatar
hide a slimjim somewhere on the outside of your car...
apparently you can get in in a matter of seconds... on your first try
or just keep a key in your wallet...
Old Apr 10, 2005 | 11:40 PM
luke4907's Avatar
Engine: TPI350
i think i have a gift... i wasn't even 5 minutes into it using a slim jim and i got in, and I have never used one before, had no idea where to push or pull, maybe luck, oh well
Old Apr 11, 2005 | 02:48 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
we coulndt jimmy my car for the life of us.......
Old Apr 11, 2005 | 11:51 PM
luke4907's Avatar
Engine: TPI350
electric locks or manual locks? the officer I borrowed the slim jim from said I wouldn't get in because it was electric locks.... HA!
Old Apr 12, 2005 | 12:20 AM
ScrapMaker's Avatar
I'm pretty sure that doesn't matter... as they are very simlar... only an actuator is the difference... I think
Old Apr 12, 2005 | 03:21 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
manual
Old Apr 13, 2005 | 12:37 AM
luke4907's Avatar
Engine: TPI350
I'll chalk it up to luck then
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Dialed_In
Aug 20, 2015 01:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
guy76767
Aug 6, 2015 05:58 PM
