svc from 4thgen to 3rdgen
Old Jan 31, 2006 | 11:59 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
hi, i saw on the forum How to on SCV 4th gen in 3rd Gen it said find the green wire with the black stripe and connect that to the 16th pin, but on my 84 z28, 5sp, my ECM harness have no green wire with black stripe, i have attach a picture, any help would be appreciated, thank you.
Old Feb 2, 2006 | 11:29 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
hi, has anybody install 4th gen delco radio into our 3rd gen and make the svc work? i can't seem to make it work, any help out there? thanks
Old Feb 5, 2006 | 11:11 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
the picture in the link is locked, anybody know why that is?
Old Feb 6, 2006 | 07:30 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I feel bad that no one has an answer for you, I don't know that I do.
Then you need to get your ECM from out of the passenger side dash area and unplug the black connector (VSS buffer) from the yellow harness mounted on the ECM. Find the green wire with the black stripe and connect another wire (long enough to reach your radio bay) to it:
But you need to start be checking the wiring diagram for you car and find the VSS wire to the computer. It may not be the same color in your car or localtion.
Old Feb 6, 2006 | 08:05 AM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Well, this could be the problem... Is your 5-speed a T56 or just a T5? Because if it's just the original T5, then you likely don't have a vehicle speed sensor.
Old Feb 6, 2006 | 09:17 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
He should have one behind the dash (speedo) for the computer.
Old Feb 6, 2006 | 10:06 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks everybody for the info, my is the original t5, and if it is in the back of the speedo, which color of the 3 wire would it be, thanks for the reply.
Old Feb 6, 2006 | 11:05 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Originally posted by NEEDAZ
...you need to start be checking the wiring diagram for you car and find the VSS wire to the computer...
May try the electronics forum, Probably get a better response over there. Don't forget the button. Try narrowing the search to the forum, and concentrate on posts by Trickster.
Old Feb 7, 2006 | 11:08 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks for that info, and i will check in the electronic section.
Old Feb 7, 2006 | 12:55 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
pre 1990 f-bodies with a standard transmission do not have a VSS. You can purchase one and install it inline with your speedometer cable at the transmission and run the wire into the vechicle
Old Feb 7, 2006 | 06:17 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
I could be wrong, hope not, but I thought the computer still had an input from the box behind the speedo? Is that just for TCC control in the autos? Doesn’t the EGR or something have a min. speed to enable?
RSFreak
Nov 21, 2001 10:23 AM
Jza
Oct 27, 2001 03:30 AM
IROCketZ28
Car Audio
Jul 25, 2001 07:24 PM
Graeme'sFirebird
Car Audio
Jul 18, 2001 02:52 PM
350iroc-z
Car Audio
Mar 29, 2001 10:36 PM
