Built a vinyl set of kicks
Old Apr 3, 2006 | 09:37 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I just finished building a set of kicks that I wrapped in vinyl. This was certainly a new experience for me. I've worked with vinyl a lot of times, but never on something with the complex shapes and tight curves of my kick panels. It wound up being necessary to cut and piece the vinyl around the back side of the kicks. Fortunately, that's all hidden when they're installed.
Attached are pics of both kicks at angles similar to what will show when installed, and one is a "backstage" pic of where I had to seam it under the tweeter pod.
Attached Thumbnails Built a vinyl set of kicks-matthewclemons5_sm.jpg   Built a vinyl set of kicks-matthewclemons9_sm.jpg   Built a vinyl set of kicks-matthewclemons8_sm.jpg
Old Apr 3, 2006 | 09:40 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
pretty slick. nice work, as always.
Old Apr 4, 2006 | 12:16 AM
Gummie's Avatar
Car: 88 GTA
Axle/Gears: 9 bolt w/ 3.73
2x but I'm personally glad I went with carpet
Old Apr 4, 2006 | 07:19 AM
Jim85IROC's Avatar
I personally like the carpet better too, but if I had an interior with the vinyl door panels and non-carpeted factory kicks, I think the vinyl would look more appropriate.
Old Apr 4, 2006 | 07:48 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
nice job Jim! I was going to vinyl over my carpeted kicks to give it a "padded" vinyl texture, but I decided not to. Regardless, they look good!
Old Apr 4, 2006 | 08:26 AM
Jim85IROC's Avatar
Vinyl right over carpet would be a disaster. It wouldn't stick, and you'd never get the look you're going for. Unless it's on a flat surface, vinyl has to go over a hard material.
Old Apr 4, 2006 | 10:05 AM
jmoney843's Avatar
Car: 89 Iroc Z
Engine: 350TPI
Wow, those look really...really good. Props on them, beautiful work!
Old Apr 4, 2006 | 11:59 AM
jimp2001's Avatar
Engine: LO3 305 TBI
I've done it a few times and had good results, but not on a complex shape. Give it a shot on a scrap piece of MDF you've got laying around. It's pretty cool.
Old Apr 4, 2006 | 03:45 PM
Jim85IROC's Avatar
On flat surfaces, I've done it over foam many times. It does give an interesting appearance, and if you don't have the abilities to flush-mount your stuff, this helps give a similar look.
Old Apr 4, 2006 | 11:13 PM
Enigma_valar's Avatar
Car: 1991 camaro rs
Engine: v6 3.1
Transmission: auto
They do look awesome sent you an email thanks a ton man
Old Apr 12, 2006 | 12:16 AM
barspin89's Avatar
Car: 85 Trans Am
Engine: 305 LG4
Transmission: 700-R4
Jim if you're still selling these kicks I'm in the market. If you could get back to me I'd appreciate it. My email is barspin89@adelphia.net.
Andy
Old Apr 12, 2006 | 11:20 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Nice job Jim!
Vinyl is a major PITA. Interesting tweet location.
Old Apr 12, 2006 | 11:25 PM
Gummie's Avatar
Car: 88 GTA
Originally Posted by REZN8R
Nice job Jim!
There's a voice from the dead.
Any chance of posting your box plans now
Old Apr 13, 2006 | 12:36 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Holy **** *L* that looks awesome.
Jim, one advice, as to how to fix the area where one can see the cuts, in case you ever feel like doing some more and want to avoid it.
Get a vinyl repair kit, in this case, the black paste, put it on, and heat it/press it with the pattern supplied that will match the vinyl you're using.
fasteddi
Sep 2, 2015 10:29 AM
InfinityShade
Aug 22, 2015 08:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
