Wierd antenna problem...
Old Sep 26, 2006 | 07:00 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Every time I turn on my radio, especially when I use the FM Transmitter for my iPod, I there is a loud static that corresponds to the RPMs of my engine. It sounds to me like the antenna is picking up interfearence from the ignition system. 1. What is the cause of this? 2. How can i fix it?
I just bought this antenna brand new from GM as a replacement(not sure if it's the original kind that came with the car or not) and installed in myself.
Old Sep 26, 2006 | 09:10 PM
thaforce's Avatar
Car: '91 Z-28 Hardtop
Engine: 5.7L TPI L98
That is most likely noise from your alternator. It can point to early signs of your alternator failing, but could probably be cleared up with a good quality noise filter.
One question when you are using the iPod, is it or your FM transmitter plugged into your cigarette lighter socket?
First place to troubleshoot alternator whine in a system is looking for a poor ground.
Old Sep 27, 2006 | 02:44 PM
85cmroz28's Avatar
Engine: L69
Do you mean a ground for the electrical system or for the antenna?
Old Sep 27, 2006 | 09:24 PM
thaforce's Avatar
grounding of the audio system
Old Sep 27, 2006 | 09:25 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Did the noise start when you replaced the antenna? Or did you replace the antenna to try to stop the noise?
Old Sep 29, 2006 | 01:54 PM
85cmroz28's Avatar
Engine: L69
Actually, the noise started about 3 weeks after I replaced the antenna. The antenna worked great for a few weeks, then started getting worse.
Old Sep 29, 2006 | 02:16 PM
thaforce's Avatar
I still think it sounds like the beginning of the end for your alternator.
Old Sep 30, 2006 | 12:23 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
If you unplug the ant. is it still there?
Old Oct 1, 2006 | 09:18 PM
SaintedCorrupt's Avatar
Car: '85 TA
Engine: Carb'd 350, ported 416s
Transmission: retrofitted T5
Axle/Gears: 3.42 7.62" 10-bolt, locker
couldnt you just listen to the radio with the car off to see if it's the altenator?
Old Oct 1, 2006 | 09:55 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
No, it only happens when the engine is running as he said (or implied). My radio actually has a static fit when I lower or raise my driver side window. Its not a real hassel since I don't play with the window the whole time, just kinda wierd haha. (Power windows btw)
I heard a long time ago that (IIRC) resistors were put into the spark plugs to reduce radio interference. Maybe it wasn't a resistor, maybe it was a capacitor or something, however those deal more with DC noises.
Old Oct 1, 2006 | 10:21 PM
85cmroz28's Avatar
Engine: L69
To make it clear, it ONLY does this with the engine running, it sounds fine with the engine off. Just curious, but how can the ateernator make that interfearence when it is so far away from where the antenna is?
Old Oct 1, 2006 | 11:18 PM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
The alt. would be putting the noise ON the B+ line. There no noise when playing CDs?
Old Oct 2, 2006 | 02:44 PM
85cmroz28's Avatar
Engine: L69
No noise while playing CD, only when playing the radio.
Old Oct 3, 2006 | 03:07 PM
thaforce's Avatar
Kinda sounds like some sort of wierd ground loop. Next I would probably try taking the ground wire from the radio and making sure it is attatched to a solid chassis ground.
If you have access to a volt/ohm meter, I would measure resistance between the center pin of the antenna connector and the outside ground fingers and make sure the antenna isnt shorted out. also measure from the outside ground fingers of the antenna connector to the car body to make sure it has a good ground.
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mud runner
Nov 2, 2015 07:30 PM
lanceflame44
Sep 25, 2015 12:28 PM
scottmoyer
Sep 7, 2015 07:06 PM
andy74
Sep 3, 2015 08:41 AM
