Choosing An Aftermarket Head Unit
Old Jan 27, 2008 | 03:55 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
I need help picking out an aftermarket head unit for my 86' Trans Am. There are so many to choose from and I'd like your help picking one thats gonna give me the best bang for my buck. I'm looking for one that has an aux input for my iPod but I'm not picky if its in the front or back of the head unit. I'm looking to spend no more than $150, not including the iPod cable I'll need, if possible.
Old Jan 28, 2008 | 11:56 AM
stereojnky's Avatar
Car: 1992 Rs
Re: Choosing An Aftermarket Head Unit
Get it while it's hot!
http://www.crutchfield.com/S-r8omQ5P...px?I=020DXZ475
You also get 20 bucks off of the ipod adapter if you don't want to use the aux input on the front of the unit. Still got change left over for some cables, wiring or sound deadening.
Last edited by stereojnky; Jan 28, 2008 at 12:00 PM. Reason: Automerged Doublepost
Old Jan 28, 2008 | 12:06 PM
redkaz04's Avatar
the cheapest is not always the best IMO. Then again, the most expensive is not always the best. With that in mind, I recommend the Apine CDE-9872. Best buy has it along with several online companies, including crutchfield. The ipod cable can also be purchased for an extra 29 bucks....good luck
Old Jan 28, 2008 | 02:31 PM
Stippy17's Avatar
I've found a head unit for a little more money, but most all of the reviews are 4 or 5 stars. The interface is appealing unlike alot of others I've seen. This is probably the one I'll go with unless someone recommends another.
http://www.crutchfield.com/App/Produ...684&tab=review
Thanks for your help guys
Last edited by Stippy17; Jan 29, 2008 at 11:33 AM. Reason: Had an extra http:// in the link.
Old Jan 28, 2008 | 09:00 PM
redkaz04's Avatar
the link does not work.....is it a pioneer...?
Old Jan 28, 2008 | 10:44 PM
stereojnky's Avatar
Car: 1992 Rs
Take the extra "http//" off of the link...
Old Jan 29, 2008 | 11:32 AM
Stippy17's Avatar
Yes it's a Pioneer DEH-P4900iB.
Sorry for the extra http:// guys..
Old Jan 29, 2008 | 12:38 PM
redkaz04's Avatar
nothing wrong with that unit except the controls are harder to learn to use and a bit more complicated. The alpine i recommended has three big buttons on the face that were designed specifically for ipod use ....makes life easy..not to mention it is cheaper. just my 2cents
Old Jan 29, 2008 | 12:43 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Get a bigger one that just a single din! Maybe this is superficial, but I picked up a 1.5 din head unit and I kind of wish I had gotten a double din. All that space is there, why not use it?
Old Jan 30, 2008 | 02:15 PM
Stippy17's Avatar
According to Pioneer's website Firebird's are a 1.5 Din, not a Double Din. When I bought the car it already had an aftermarket head unit in it (Am and CD's work but FM doesn't & I've already replaced the Antenna, and I want a head unit that incorporates an Ipod) so I shouldn't have to mess with fitting the new one in there too much.
Old Jan 30, 2008 | 04:02 PM
brandotron's Avatar
I followed the same Pioneer specs when I chose my 1.5 din and I have a good .25" on the top and bottom of my head unit. To each his own, but the next head unit I buy will be a double din. I might have to do a little fabbing for a bracket, but it should fit in the console with no problems.
Nice Trans Am, BTW.
Old Jan 30, 2008 | 08:33 PM
Stippy17's Avatar
Nice Trans Am, BTW.
Ok, I'll keep in mind those specs are off. Thanks for your help brandotron. And thanks lol, its definetely a work in progress and still has a long way to go but I'm 17 and excited to own and restore such a car.
I'll post pics up in a week or two once I buy the unit and install it.
Old Jan 30, 2008 | 09:03 PM
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
well just about any pioneer or alpine will sound good so just pick one up get an amp an a sub an some new speakers an you got a nice sound system
Old Jan 30, 2008 | 10:48 PM
brandotron's Avatar
Seriously, at the end of the day, just get a name brand and you'll be fine. GET AN AMP AN SUB. Even if you go cheap on it, it'll make your stereo sound ten times better.
Keep us posted if you do that 350 swap!
Old Jan 30, 2008 | 11:17 PM
1991ON20's's Avatar
Car: 91 RS, t-topped, man trans.
Engine: 350cid 350Hp crate motor
Transmission: t5 with new stock clutch and parts
Axle/Gears: 3.08 stock -RS
flip out screen from Jensen. NOt a big name but the head unit has a lot of features. I pod cable too! ..........for what i need my ultimate stereo to be this H.unit delivered!
Old Jan 31, 2008 | 11:11 AM
MärkJ's Avatar
Car: '88 Pontiac T/A
Engine: 305ci
Axle/Gears: LSD
Can't go wrong with a Pioneer. I've never gone back to any other make.
Old Jan 31, 2008 | 11:36 AM
Stippy17's Avatar
Thanks for all the help guys..I'll post pics up when it's installed in the car.
Those are next on my list, just need to put the money aside little by little til I have enough. The car wont be on the road for a few more months still so I still have time. I'll def keep you posted on the swap too.
Ghettobird52
Jul 5, 2024 11:18 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
ZsTransAm
Aug 11, 2015 07:30 PM
