CUSTOM MADE SUB BOX
Old Jan 20, 2009 | 08:26 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
CUSTOM MADE SUB BOX
I just got done with a custom made subwoofer box for 2 10's and just wanted to get some thoughts on it it still need a little things here and there but its done for the most part its done tell me what you think.
Attached Thumbnails CUSTOM MADE SUB BOX-img055.jpg   CUSTOM MADE SUB BOX-img054.jpg
Old Jan 21, 2009 | 01:10 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
Re: CUSTOM MADE SUB BOX
Is that plexi screwed on top of the carpet? If so, it's going to leak air BIGTIME.
Old Jan 21, 2009 | 03:25 PM
Steveh4263's Avatar
Car: 1987 Pontiac Trans AM GTA
Engine: 5.7 LTR
Transmission: Automatic
That's what I want to make for a cd changer and amp. I would want it a little lower than that so I could still put some stuff in the well area. Probably some sort of lid so I could get at the magazine for the cd changer and maybe some fans or something to keep the amp cool since it is in a enclosed area. I'd like to get the dimensions of your sub box or plans. But It is a very good design. Could you send me a private message with dimensions and plans on how you made this? I like how you can still use the light in the well area, that was a good idea.
Old Jan 21, 2009 | 03:36 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Some better pictures of the set up and build would be awesome!
Old Jan 21, 2009 | 07:45 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
I never thought about the air leak at the plexi any suggestions on how to stop the air and still keep the look that it has. And like i said it still has some work that has to be done to it. Such as where am i going to put the amp????
Old Jan 21, 2009 | 07:54 PM
Steveh4263's Avatar
Engine: 5.7 LTR
I would put the amp in the sub box or some where on top the sub box. You could put the amp under the plexy glass? Can you drill holes in plexy glass for venting for the amp. Just some ideas I'm throwing around.
Old Jan 21, 2009 | 09:17 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
It's a little late in the process, but what I typically do is counter sink the plexi with a router using lots of screws and silicone sealant. To hide the screws and silicone build a trim ring out of 1/4" board, cover it in matching carpet and screw it down in the corners with decorative screws.
Old Jan 22, 2009 | 09:10 AM
Car: 1992 Camaro RS
Engine: 350 Carb'd
I'd stay away from mounting your amp on or in your box, only because the vibrations from the subs can damage and rattle things loose in the amp. Many people have built a amp rack for where the spare tire goes so its hidden and well ventulated. Right now I have mine mounted on the hump behind the backseat but I am looking into the amp rack idea for the spare tire space.
-Darren
Old Jan 22, 2009 | 04:21 PM
hellsatan's Avatar
Car: 89 IROC
use clear silicone to make a good seal for the plexy. just dont glob it on so its looks really really bad. I was lil scared with my box so I just silconed my subs in they wont leak ever . My box is bomb proof its got lots of silcone in and out from prev owner drill holes.
Old Jan 22, 2009 | 04:24 PM
-srs-'s Avatar
Car: 1991 Z28 Vert
I use rope caulk for my subs. Makes working on them a lot easier. It's available in just about any hardware store.
Old Feb 7, 2009 | 02:54 AM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
-Darren
x2
Old Feb 8, 2009 | 07:50 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
i'd add some accent lighting in the sub box for effect... seein that you have the plexi in there
Old Feb 8, 2009 | 09:08 PM
ClickClickVroom's Avatar
Car: 92 Z03 RS TBI
Engine: 5.0 L03
I second the visuals. Is that tin foil in the first pic ? :P
ANd dont enclose your amp inside with the subs...
Heat build up much?
But all in all looks good. Did you just use the normal sub box for the basic dimensions then alter the top?
Old Feb 8, 2009 | 10:09 PM
cjohn310's Avatar
Car: 1992 FIREBIRD
Yes I planned on puttng lights on the inside I just have to find a style and color that I like. But thatw ay foil on the inside but I had a problem with it. I guess that it was not glued down hard enough because it rattled BAD so I had to pull the top off and get all the foil out and then reseal the thing. And to anwser the question about the measurements we cut the piece that covers the rear hatch moter right under the lip that the box sits on. Then took the box all the way to the wall that the tail lights connect to. So pretty much the box lookes like a box letter L with the top that you see when you look at it. Thanks for the posts.
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
NORTz89
May 20, 2020 03:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
