Need help with head unit
Old Sep 16, 2009 | 06:34 PM
Mike4568's Avatar
Car: Chevrolet Camaro
Engine: LO3 V8
so i have an alpine x300 with new speakers an everything. i do notice that the dash dims a bit when its loud.i want to put a KTP-445 which gives 45wx4 RMS but im worried if the stock cables in the car can give enough power to it. has any1 used KTP-445 b4?
Old Sep 16, 2009 | 06:43 PM
87 WHITE GTA's Avatar
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: Need help with head unit
U need a bigger battery.If u already have a decent sized battery u can also upgrade the distributor cables.My POS battery I had made my headlights dim and my HU when playin at high volumes.It would also take a lot longer to start my car up.If I was u I'd try to upgrade those 2.
Old Sep 16, 2009 | 07:08 PM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
do the big 3 upgrade, it include the positive from alt to battery, engine ground to batt, and chassis ground to bad... switch these cable to 0 gauge cable... u might also want to run a direct power cable from the battery with a fuse in between of course to your radio, 10 gauge should be more than fine.
Old Sep 16, 2009 | 07:14 PM
Axle/Gears: Stock
Old Sep 16, 2009 | 08:59 PM
DJ Delsym's Avatar
Car: 86 Iroc
Engine: Soon to be LS 6.0
Transmission: Soon to be mn12
Axle/Gears: Strange 9in 4.10
I would look to a new alternator and possibly a new battery. There is no reason why your lights should dim even with stock wiring. I didn't upgrade my 'big three' because there isn't a justifiable reason for it. The wires do the job; better wires make them do their job better, but it won't solve a problem that isn't associated with the wires themselves.
Old Sep 16, 2009 | 09:02 PM
soocrispy89's Avatar
Car: 1989 firebird ssa
or you could also put a capacitor in the lines to help hold the charge to the rest of your electronics so it doesnt drain your battery. you would only need probably a 150 farrad cap.
Old Sep 18, 2009 | 04:28 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
id get a farad cap...
Old Sep 20, 2009 | 01:34 AM
Axle/Gears: Stock
I think stock wiring,battery,alt etc. works ok with stock equipment, since everything is designed to work together,but when u break that "everything-works-good-as-long-as-its-stock" environment and add aftermarket HU's, power demanding electronics and power hungry speakers u break that balance and thats when a wiring upgrade becomes more of a need.
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
ZsTransAm
Aug 11, 2015 07:30 PM
