power antenna on the fritz
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, the power antenna on my 91 Trans Am suddenly just went bad (like this morning) and the thing with it is that the motor can't seem to get a good grip on the antenna. It'll go up on its own pretty well, but when it needs to come back down when I turn the car off it gets stuck and the motor keeps going and going. I assumed that it would stop after a while but it doesn't seem like it. I have to go out and push the antenna down a bit so it can grab and then it slowly goes down. I was wondering if there's a way to disconnect the motor so the antenna just stays up all the time so I don't have to worry about forgetting to push the thing down and the motor killing the battery (A way to possibly fix the antenna permanently would be nice if anybody knows too). The fuse for the antenna also controls a few other things so I can't pull it out. Any help would be great.
Car: 1987 Trans am (SOLD), 1986 Trans Am
Axle/Gears: Stock
Re: power antenna on the fritz
I'd beat the crap out of the antenna,pour water while its up to short it out,or maybe you could take out the radio and cut the blue wire in the radio harness while the antenna its up (without current flowing through the wire obviously), crimp both ends of the cable to prevent shorts and you should be good to go.
Engine: LB9
Axle/Gears: Stock
you could use spade connectors.....(like the ones you use to connect speakers)....idk lol
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Remove the knee panel on the passenger side of the dash, there is where the relay is, once the antenna has gone up, pull both plugs out of the relay to eliminate any possiblity of a draw or signal. The plugs should be facing you, and there are 6 wires for the power antenna.
Engine: LB9
The reason it will not go back down is inside the antenna itself there is a plactic strip that has little teeth on it and its about a good two in half feel long this allows the motor to make the antenna go up and down. When this breaks or the teeth start to where out it will not go up or down. You can get a replacment antenna mast for like twenty bucks but it has to be the one for that type of power antenna. Obviously the motor is still good because you can hear it running. Also there should be like a quick disconnect for the antenna it self so you can remove it you should just unplug that so you dont have to cut any wires.
sailtexas186548
08-24-2015 10:11 PM
