switch?
Old Feb 10, 2010 | 10:24 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
switch?
I did a quick google search on radio switches but i couldnt find anything. My durango, would keep the radio on all the time unless i bought the $80 radio harness. So I just installed a neat looking little switch and used that to turn it on and off. I really liked it also because i could actually turn the radio off while driving, the radio i have will not ever turn off unless the car is off, you just have to mute it.
Anyway, does anyone else do this?
Old Feb 11, 2010 | 12:51 AM
ellocojorge's Avatar
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: switch?
did you have it hooked up correctly? was this a stock radio or aftermarket?
Old Feb 11, 2010 | 12:17 PM
TTA579's Avatar
Car: Turbo Trans Am #579
Engine: 231ci (3.8L) LC2 (Buick Turbo)
Transmission: 200r4
Axle/Gears: Borg-Warner 9-bolt
Re: switch?
I've never seen a radio without a power button. Any radio sold on this planet in this century should be able to shut off while receiving power, unless it's broken.
Old Feb 11, 2010 | 02:12 PM
Engine: 383 Stroker
Transmission: t-56
Re: switch?
i have a pioneer unit with usb hookup. bought it new for 200 bucks just a few months ago.. no power switch.
Old Feb 11, 2010 | 02:36 PM
TTA579's Avatar
Transmission: 200r4
Re: switch?
I believe those models shut off when you hold down the SRC (source) button for 3-5 seconds.
Old Feb 11, 2010 | 04:02 PM
Engine: 383 Stroker
Transmission: t-56
Re: switch?
really?? im gonna try that out. do you know how to auto-scan for radio stations too? I cant figure it out.
Old Feb 11, 2010 | 07:20 PM
TTA579's Avatar
Transmission: 200r4
Re: switch?
For that info, I'd have to know the model number. I've been looking at the Pioneer units lately, but their confusing controls have me looking at Eclipse and Alpine instead.
Old Feb 11, 2010 | 09:06 PM
Engine: 383 Stroker
Transmission: t-56
Re: switch?
yes the controls are rediculous...
Old Feb 12, 2010 | 01:31 AM
Car: 1991 camaro rs
Engine: 305 tbi
Transmission: t5
Axle/Gears: stock
Re: switch?
did you make sure you hook up the yellow wire from the radio to the battery constant, and the red wire to remote?. i get the feeling you either hooked them up together, or switched them.
Old Feb 12, 2010 | 01:38 AM
Brendan91Z's Avatar
Car: 1991 Camaro RS, 2013 Camaro SS 1LE
Axle/Gears: Stock
Re: switch?
did you do this because you have no acc 12? or you only have a 12v source? not normal its most likely hooked up wrong and liike2stroke i think you hold down the seek button and it will scan for you and pick up the strongest ch.s
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
