Double Din Head Unit Post Your Pics
Old Feb 7, 2011 | 04:15 AM
Guest
Guest
Posts: n/a
MY Pioneer
This is what i did to my Camaro, i took the face plate out made some measurements and some cuts, also took out the back plate from the inside of the dash that holds the radio to not drop in more then its limited to do so, you will see it once you take your radio out. unscrewed the temperature controller and put the unit right in then pressed a little with the temperature control plate on the unit so that holds it in place real good screwed the control plate back and put the face plate back on.
It dose not move or vibrate its a real real tight fit.
only thing left is to put a trim on the sides because there is some space so i will post the rest of the pictures once i have done that.
Attached Thumbnails Double Din Head Unit Post Your Pics-photo-3-3.jpg   Double Din Head Unit Post Your Pics-photo-5-5.jpg   Double Din Head Unit Post Your Pics-photo-7-.jpg
Old Feb 7, 2011 | 06:03 PM
Guest
Guest
Posts: n/a
Re: Double Din Head Unit Post Your Pics
These are the rest of the images.
Attached Thumbnails Double Din Head Unit Post Your Pics-cimg2009.jpg   Double Din Head Unit Post Your Pics-photo-9-.jpg   Double Din Head Unit Post Your Pics-photo-10-.jpg
Old Feb 8, 2011 | 10:20 AM
Hyper Tailz's Avatar
Car: 92 Camaro RS
Engine: 3.1
Transmission: Manual
what radio is that... all i see is pioneer
Old Feb 8, 2011 | 08:27 PM
88iroctpi305's Avatar
Car: 1988 Camaro IROC-Z and 91 Z28
Engine: 305 TPI and 350 TPI
Axle/Gears: unsure of ratio but POSI (:
looks good man. so fairly easy install then right?
Old Feb 10, 2011 | 09:02 PM
Guest
Guest
Posts: n/a
It's a pioneer avh-p4100
it's an easy install and worth it.
Old Feb 11, 2011 | 06:17 PM
Car: 92 Camaro RS
Engine: 3.1
thankz ill look it up been seaching around for a good one that will work with our car.. do u have a auto or manual
Old Feb 12, 2011 | 10:38 AM
Guest
Guest
Posts: n/a
auto but it dont matter
Old Feb 22, 2011 | 09:16 PM
Car: 92 Camaro RS
Engine: 3.1
reason y i ask is cuz i have a manual was wonder if the shift/auto stick hets in ur way much when picking an option. having a manual doesnt give me much time to be selecting alll the time
Old Mar 10, 2011 | 12:40 PM
mudd746's Avatar
Car: 89 IROC Convertible
Engine: 305HO
got mine done finally
Attached Thumbnails Double Din Head Unit Post Your Pics-3-10-2011-2   Double Din Head Unit Post Your Pics-pj-3-9-2011
Old Mar 10, 2011 | 03:34 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Looks fantastic. Are you happy with the head unit? I am looking for a good one. Trouble is I want GPS but hard to find on with Australian maps.
Old Mar 15, 2011 | 09:43 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Mudd746- How'd you get the texture look on the final pic? It looks damn good. Factory.
Old Mar 16, 2011 | 12:35 AM
mudd746's Avatar
Engine: 305HO
masked off all i did not want texture coated, lightly misted it with a texture coat then removed all tape and sprayed it with sem paint to match the rest of the dash pieces
Old Mar 16, 2011 | 06:10 PM
Transmission: 4L80E
Hell I didn't even know they make textured spray paint. Who makes it?
Old Mar 16, 2011 | 09:16 PM
mudd746's Avatar
Engine: 305HO
sem and duplicolor. you should practice with it first different coats and distances change the look as well as angles
Old Jan 25, 2013 | 02:21 AM
salfirebird92's Avatar
Car: 92 Firebird Formula
Engine: 5.0 V8
here is mines
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TreDeClaw
Aug 14, 2015 06:58 PM
ZsTransAm
Aug 11, 2015 07:30 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
