Factory Blaupunkt Cassette Deck Repair
Old 06-24-2011, 06:42 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
Hi all, was wondering if anyone had pics or a manual how to fix the belts on the blaupunkt cassette deck. And what the belt sizes were for it. I have the uq7 stereo. Thank you very much for your time.
Old 06-24-2011, 11:09 PM
DizzTransAm's Avatar
Car: '83 & '84 T/As
Re: Factory Blaupunkt Cassette Deck Repair
Go to the Fiero store. They sell new belts they and comes with instructions. put one in 5 years ago and still goin strong
Old 06-24-2011, 11:13 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
How do i know which belt kit fits the cassette deck?
Old 06-24-2011, 11:33 PM
Car: '83 & '84 T/As
Chose the one that describes your stereo. iirc they only have on kit for the 5 way equilizer.
Old 06-25-2011, 09:08 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Thanks, sorry for all the questions but do you have pics or a manual on how to changethe belts? I have so many cassettes that need to be played!
Old 06-26-2011, 03:49 AM
Car: '83 & '84 T/As
I don't I used the instructions that came with the belt kit, do two or more and you won't even need the instructions anymore, plus I lost them. Although next time I do one I'll take pics.
Idk what the Camaro UQ7 stereo is post a pic and I'll link you to the right kit.
Old 06-26-2011, 07:24 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I have a Trans Am. It's the uq7 with the sub gain switch and 5 band equalizer. Do I have to take the stereo apart to get to the belts? The performance Sound group option
Old 06-26-2011, 05:50 PM
Car: '83 & '84 T/As
Yes its very easy though. All that matter is the equilizer on the stereo for the kit they all pretty much come apart the same. get this ( http://www.fierostore.com/Product/De...5557&d=276&p=1 ) it has instructions with it. First time out may take you 30 mins to and hour. I can do this in 5 minutes.
Old 06-26-2011, 08:10 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Thank you I greatly appreciate it. I'll try to take it apart. Last time i took it apart i could not get to the tape deck.
Old 07-01-2011, 09:11 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
I too would love to have my deck working. I had called Blaupunkt directly 2 years ago and told the rep that I was looking for belts for one of their decks from the 80's. He laughed at me. I ended up having a MP3 jack installed, but still miss the deck.
In case you can't get the belts to work but want to retain the radio and would like to be able to play MP3's, check out the following link (my post is #9) https://www.thirdgen.org/forums/car-...cks-w-aux.html
Dizz, I just ordered the belts (pictorial directions are a bonus!) and hope that this 20 bucks will get my deck rockin' again. Thanks for the link!
Thanks!
Old 07-01-2011, 10:51 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Changed the belts today and it still does the same thing, the only thing left is the drive motors =(. Idk how to fix that tho. On a side note tho, now my car goes below 500 rpm when i stop at a light what's going on? sounds like it wants to die and also at start up it'll start normally idle at the right but sounds like it wants to die too.??????
Old 07-02-2011, 10:18 AM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
what problem are you having with the cassette player?
I have been using a blaupunkt transport delco in my car
since 1993(radio came from '84 cadi)I have had to
fix it several times since then as it gets heavy usage.
Besides the usuall loose/broken belt problems and worn
heads,there are a couple other problems common with
these:
-if it crimps tapes that usually means the pinch rollers
have hardened-this is fairly common with the early
white hub pinch rollers,the later(around 1990 up)
black hub pinch rollers don't seen to have this problem
and fit the earlier versions.Older alpine pinch rollers
also fit if the bronze bushing is shaved on the sides
just a little-the older alpine ones have brass hub with
a bronze bushing.
-had a motor go bad once,brushes wore down so much
the brush position on the commutator was shifted and
motor started to run fast -apparently the motor's
speed control circuit could not compensate enough...
Old 07-03-2011, 11:08 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I will put in a tape the up and down arrows will flash and it will eject. It acts like it's changing sides and will spit the tape out. I changed the belts and it still does it. Dad said it was the motor do you think it is?
Old 07-03-2011, 12:17 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
bad motor is one of the possible causes,but there are
several others-above the reel drive pulley(usually it's
black,driven by the short belt)is an optical pickup to
detect rotation of this pulley-if the pulley stops for more
than a certain amount of time the player will switch
directions then eject the tape if pulley rotation is still not
detected.if cassette mechanism is positioned too low on
the bracket pulley can rub on bracket and stop when the
mechanism is down in the play position.
Try a clear cased cassette where movement of the tape
can be observed-if no movement probably a bad motor
or no power getting to motor due to broken wire or
other electrical problem.
Old 07-03-2011, 11:51 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I tried the clear cassette trick and it seems like no movement of the tape is occurring. What to do from here?
Old 07-04-2011, 02:53 PM
Car: '83 & '84 T/As
Go to a pick n pull and take out another cassesette drive.
Old 07-04-2011, 07:31 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I doubt my local junk yard has trans ams lying about. But, I will try. But, i'm taking a gamble with that, is there a safer way?
Old 07-04-2011, 09:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
DizzTransAm's suggestion is a good one-will get you a
spare parts stash for your radio tooyou don't need to
check for just trans ams-lots of different 1984-Ca.1994
GM vehicles used the blaupunkt tape transport in the
upper end cassette decks:check cadillacs,astros,s-10s,
buicks,pontiac 6000s etc.though those years.The later
blaupunkt transports,around 1989 up used a different
motor and i am not sure if those interchange with the
earlier ones, but its likely they do.These radios are
very common in my local junkyards and i automaticly
grab them when found most i find are in '85-90
midsize FWD cadillacs...
Old 07-05-2011, 01:56 AM
Car: '83 & '84 T/As
Bingo, the stereo in my T/A is from a 88 LeSabre with a 89 Deville cassette chassis. Just find any car with a 5 way equilizer. Cadi/Olds/Buick would be the best as their susual less used.
Old 07-05-2011, 09:01 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Okay, i will do that thanks. Btw, i've never done a pick n pull. Do i just bring my tools and some cash? I'm going to write down those car models and see if i can find any.
Old 07-05-2011, 11:53 PM
Car: '83 & '84 T/As
Yep bring $2 for entrance fees and your tools. Easyest cars to find it in is '86 - 91 Cadillac Eldorados and Seville as that style stereo was the standard one for those cars. Dash is cake to breakerr take apart
Old 07-11-2011, 11:17 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Thanks but,before I tear apart some poor car. I'm going to make a vid of what it does just to confirm it. (Better to be safe just in case)
Old 07-26-2011, 08:19 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
.... I can't find a replacement nor can i find out whats wrong with this deck. I've been researching like a mad man.
Old 07-27-2011, 02:06 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Here's the vid of the issue http://www.youtube.com/watch?v=UEKPIJfu70k
Old 07-28-2011, 02:52 AM
Car: '83 & '84 T/As
Wow it ejects pretty quick. I still say go to a self serve yard and rip out another cassette drive, should not have any difficuly finding one, any givin day I can come out with a wheelbarrow full of em.
Old 07-28-2011, 12:01 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I called about 7 local junk yards and even some that are hours away and they all said they dont have radios or those car models I mentioned. In brooklyn it's hard to find junkyards cause everybody leases in NY. Thirdgens are rare here. I'm going to keep calling though. Is there any way you can send me one? I'll pay for it and the shipping if the price is right.
Old 07-30-2011, 05:20 PM
Car: '83 & '84 T/As
That could be arranged it'll be about $40, shipped the only concern I have is that it eject and fast forward and reverse buttons won't match your deck.
Old 07-31-2011, 01:08 AM
Car: 1986 Trans Am
Engine: lb9 305 tpi
Eh, that might be a problem. DO you have another one like mine that works?
gta892000
08-11-2019 11:16 AM
PurelyPMD
05-05-2016 04:57 PM
75bike
09-20-2015 09:37 PM
John in RI
Car Audio
09-10-2015 11:24 PM
scottmoyer
09-07-2015 07:06 PM
Quick Reply: Factory Blaupunkt Cassette Deck Repair
