nav
Old Sep 16, 2011 | 09:25 PM
86camaro17's Avatar
Transmission: manual
nav
would a toyota navigation wiring fit the wiring for and 86 camaro or any camaro. Would i just have fitament issues?
Old Sep 18, 2011 | 02:49 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: nav
if youre asking will it just plug in to the stock wiring, no it wont.
Old Sep 18, 2011 | 05:31 PM
86camaro17's Avatar
Re: nav
i am asking that. how different would it be. what would i have to do to make it work
Old Sep 18, 2011 | 05:36 PM
travis401's Avatar
Car: 91 Camaro RS
Re: nav
im sure no company makes a harness to just plug the toyota nav into the stock wiring, so youll have to wire it yourself. i dont know a single thing about the toyota nav, but im guessing its a nav/radio. im also assuming all it needs is a few simple wires, like constant power, switched power, ground, and the speaker outputs. however there is the possiblity that it requires a lot more wiring than that.
Old Sep 18, 2011 | 07:45 PM
86camaro17's Avatar
Re: nav
very true. good thing im doing a wiring class at school. Thanks for the help.
Old Sep 18, 2011 | 10:03 PM
cdoyle's Avatar
Re: nav
What you could do is this.
Get an aftermarket wiring harness that allows you to install an aftermarket deck into the factory harness.
Then go cut the plug (with some extra wiring) from whatever toyota that nav came out of. Then connect the wires from the aftermarket harness to the wires/plug you cut out of the toyota.
plug the toyota harness into the Nav, plug the aftermarket harness into the Factory GM plug.
that way you don't have to cut any wires in your car.
You're also going to need to tap into the speed sensor for that Nav. Not sure if an 86 has one?? Anyone know?
Old Sep 18, 2011 | 10:06 PM
cdoyle's Avatar
Re: nav
oh, Is this a JBL Toyota Nav?
I think those are all digital too, at least it is on my 4Runner. So there are no speakers leads on it. The wires send a digital signal to an amp, and from there they go to the speakers.
If it is digital, you're better off getting an aftermarket nav. The JBL ones really don't sound all that great.
Chris
Old Sep 19, 2011 | 06:47 PM
86camaro17's Avatar
Re: nav
im getting the unit for 75. its worth around 500 so if it doesnt work out ill sell it. but i hope it does. i am getting wiring with it. not sure if it is JBL as you said. and the trans has no speed sensor if thats what ur talking about. not sure if u are.But would it be too much work to deal with u think?
dans89
Car Audio
16
Nov 19, 2010 10:57 PM
krisb410
Mar 7, 2009 01:35 PM
burnout88
Car Audio
Nov 16, 2008 01:05 PM
Goumba T
Aug 22, 2007 04:45 AM
