Need help choosing an amp...
Old Mar 24, 2012 | 06:21 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
OK, I need some help choosing between these two amps. I have a couple guys with these locally that I have been talking to. Both are new in the box. Will be using this amp to power a pair of alpine 6x9's and later on powering a single sub..... Which of these are the one to go for? both are priced at $100.00 here locally...... I am not very fluent in car audio specs and want your thoughts on these.....
Fosgate R400-4D
http://www.sonicelectronix.com/item_...e-R400-4D.html
Hifonics TXI-6408
http://www.sonicelectronix.com/item_...-TXi-6408.html
Old Mar 25, 2012 | 02:35 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Need help choosing an amp...
Anyone? Need some of the audio guru's opinions here.... Personally, I am leaning towards the Rockford Fosgate Amp....
Old Mar 25, 2012 | 10:23 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
What is the RMS of your 6x9's? Both amps are 4 channel amps, not good for a single sub later on, just so u know
Personaly I'd run a 2 channel amp and when time comes bridge it down to a 1 channel for your single sub
Old Mar 25, 2012 | 11:49 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
The 6x9's are 75 watts rms at 4 ohm.... Figured pushing a few watts over rms wont hurt anything.... I wanted the 4 ch in case I do some add ons at a later date.
For a sub, I was told I could always bridge out 2 channels for it since both can operate in tri mode....
Old Mar 25, 2012 | 11:50 AM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Reading the specs, they dont seem very dissimilar....
Old Mar 25, 2012 | 12:04 PM
GreenCamaro13's Avatar
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
IMO Bro, your BEST and most EFFICIENT best would be to go to amazon and look up Pyramid Arctic Amp, 40$ and is 1000W. im using one right now, i will load a vid of it to show the magic. i have 2 12's hooked up to it( Kicker And A Alusonic) and they BUMP!! love them. and if the amp is about to overheat it shuts itself down and cools down. many awesome feutures, just IMO man, $100 for 400W isnt so good.. ripoff. GL man
Old Mar 25, 2012 | 01:07 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
You want a 4 channel for your speakers and a two channel for your sub
Usually 4 channels are not that powerfully enough to power a sub unless its a Walmart sub
Old Mar 25, 2012 | 01:10 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
That's not good that your amp overheats and shuts off your smoking your amp and you get what you pay for in audio I have 2 jl audio w6 with 1000 what amp kenwood bridge and subs are wired parallel in a custom ported box I have that overheat future on my amp but it never shuts off Ive seen a amp catch fire in a car yea that was my car lol with a temp cheap amp
Old Mar 25, 2012 | 01:21 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
well works for mine man, i litterally at times put maximum bass and it shakes the windows and wont turn off till like 45 minutes and has not once failed me. love it. as for the fire, howd that happen?
Old Mar 25, 2012 | 01:39 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Cheap amp overheated lol
Yea I set off car alarms and shake the inside of my apt lol
Old Mar 25, 2012 | 01:40 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
nice lol, well not bad for a teen with no money lol, wish i had more $ then i would go all out lol
Bad@s car btw
Old Mar 25, 2012 | 01:43 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol true I get most my stuff used or on here or trade
Old Mar 25, 2012 | 01:44 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
yea but like i said, for 40 $ and a 1000W amp, its not bad at all, especially since you will hace 60$ to spend elsewhere on the car.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Thanks your car is ba to man I'm waiting for new wheels to come in I'm changing it up
Old Mar 25, 2012 | 01:45 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
True got to love amazon eBay junk yard lol and thirdgen.org
Old Mar 25, 2012 | 01:47 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
heck yea man, now im looking for a CAI for my maro' but cant find..
so what are you getting Coryprine?
Old Mar 25, 2012 | 01:53 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
What's corypine
Go to a junk yard and autos tore and make your own
so what are you getting Corypine?
Old Mar 25, 2012 | 01:56 PM
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
the one who made this thread lol
Old Mar 25, 2012 | 02:05 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Lol
Old Mar 25, 2012 | 03:55 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Most likely, I am going to get the Fosgate
Old Mar 25, 2012 | 04:56 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
There a good brand I think quality went down since they went mainstream
Old Mar 25, 2012 | 05:07 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
The important thing is what type of box you plan to run cause that's makes a world of difference
Old Mar 25, 2012 | 11:33 PM
inkedbass's Avatar
Sorry man but spend more money, get better quality, and not have to worry about it shutting off. Just like anything else a protection circuit can fail and your amp can go up in a puff of smoke. ESPECIALLY if its shutting off after 45 minutes. I have a smaller PPI amp that doesn't even put out 500 watts in my wife's Xterra on 4 8" subs and I can go 3+ hours with the music cranked up and have NO issues.
Spend the money and get yourself some good audio equipment. Would you rather buy an amp, or other parts two or three times because they fail, or would you rather spend a little bit more and only make that purchase once?
J
Old Mar 25, 2012 | 11:36 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Both good amps flip a coin
Old Mar 26, 2012 | 12:13 AM
Engine: 305 to 350
Axle/Gears: 10 Bolt
J
I agree I got jl audio w6 and still lasting had for 7 years
Old Mar 26, 2012 | 02:30 PM
inkedbass's Avatar
The W6 subwoofers were truly ahead of their time.
J
bjpotter
Oct 4, 2015 07:48 PM
Vincent135
Sep 28, 2015 10:50 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
Victor6
Aug 30, 2015 02:09 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
