84 camaro stereo
Old 05-30-2014, 05:00 PM
leoguy67's Avatar
84 camaro stereo
Anyone know if wiring is same from 84-94? For stock stereo?
Old 05-30-2014, 05:12 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: 84 camaro stereo
Look here: http://www.austinthirdgen.org/index.php?pid=45
Old 05-30-2014, 05:24 PM
leoguy67's Avatar
Thanks but I really didn't find any info there comparing 84-94 stereo wiring.
Old 05-30-2014, 05:46 PM
*84TA's Avatar
Car: 84 Trans Am
94 is different from 84 . GM went from the 12 pin to 21 pin connector in 88 in cars and 91-92 in trucks and vans. You can buy an adapter to go either way from Metra.
Old 05-30-2014, 06:04 PM
leoguy67's Avatar
Cool thanks just saved alot of grief. Was just about wire buddy money for a stereo that I probably couldn't hook up.
Old 05-30-2014, 06:52 PM
*84TA's Avatar
Car: 84 Trans Am
You can hook it up with the factory harness if you still have it installed in your car. You will just need the proper adapter. What radio were you looking at buying? I may be able to help you find a suitable solution to wire it in.
Old 05-30-2014, 06:55 PM
leoguy67's Avatar
I bailed on buying that stereo. But can you tell me up to what year of camaro will work without hassle?
Old 05-30-2014, 07:54 PM
*84TA's Avatar
Car: 84 Trans Am
Anything from a 82-02 will work. Just depends on the style you want. In fact almost any 1.5 din GM radio will work.
Old 06-01-2014, 07:02 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Of course you could get an aftermarket HU and humount plate
zerogsx
02-06-2016 11:29 AM
69 Six Pack
10-05-2015 07:51 PM
Rakim_RS25TH
Car Audio
08-20-2015 06:22 PM
Rakim_RS25TH
08-18-2015 09:32 PM
Quick Reply: 84 camaro stereo
