Double Din
Car: 89 IROC Convertible
Engine: 305HO
Double Din
I've had lots of emails regarding the dash kit i made for my camaro so i am deciding to do a write up with pics about it.
Pic 2 is center console out and Pic 3 is the center support tab cut off. I have seen some with the whole middle support has been removed and it may work but i don't want the console to start and split or get wider over the years as well as may cause gaps after trim plate has been made.
Engine: 305HO
Re: Double Din
Pic 1 is the air vents had to be melted down to accommodate the larger size of the double din. They could have been cut off but mine are still functional as is does help keeping it warm for the two weeks of winter here in AZ. Pic 2 is the aluminum brackets i made to hold radio and mount to dash of vehicle. Pic 3 is sizing up and seeing what needs to be cut and filled
Engine: 305HO
Re: Double Din
Pic 1 Attached trim ring temporarily with tape and CA glue. Routered out top and bottom of dash to correct size opening or deck. Pic 2 dash cut. Pic 3 is filling in sides with ABS plastic and attaching with CA glue
Engine: 305HO
Re: Double Din
Pic 1 both sided filled crack between ABS and dash kit with CA glue Pic 2 is the back side. Pic 3 is sanded down level
Engine: 305HO
Re: Double Din
Pic 1 Is test fitting kit on deck. Pic 2 is light body filler to fill in any gaps that may have been missed and masked off where i don't want any texture coating like the inside where AC controls mount and the outside edges of the dash. Pic 3 Is texture coated to match original texture and painted with SEM Landau black paint.
Engine: 305HO
Re: Double Din
Some ask what CA glue is and its Cyanoacrylate adhesive or Super Glue. That is a older Alpine IVA-W205 I now have the Alpine IVE-W535HD and it bolted right in without any modifications. The old Alpine was sold. The Iphone or Ipod cable are in the center console. I used Poof or black suede flocker to finish the inside so it was the luxury BMW or MB feel.
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Double Din
WOW! that looks really nice. If you could make one for sale... How much would you charge for it?
Car: 1989 IROC-Z, 1986 IROC-Z
Engine: 350 TPI, 305 TPI
Transmission: 700R
skinny z
Oct 5, 2015 06:23 PM
IROCNParts
Sep 24, 2015 10:50 AM
