Bare-bones bass
Old Jan 30, 2001 | 02:59 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Bare-bones bass
Hey all, here's my challenge. Give me the smallest and least obtrusive way i can get some bass into my vert. I don't need anything earthshaking, just something so i can hear some good low frequencies.
The challenging part is this. I would prefer to lose no trunk space, it's cramped enough in a vert. My first idea would be under the back seat(s) It's been too cold to take 'em out to measure, but from memory it seems like i could get maybe an 8" or so in there. Small i know, but it would be better than nothing right. And what about under the front seats. Besides the obvious theft threat, could it work.
If i have to lose trunkspace, it has to be a minimum. Like a free air 10" sitting in there. Or an absolutely minuimum sized truck box.
So, which one of these sounds like my best bet. Or should i just abandon the sub idea altogether and get a great set of 6.5" full ranges and drive them with a great amp. I need to get the speakers (and an amp if you read my other post) anyway, but i wanted to buy them more for clarity than raw power handling and bass.
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Jan 30, 2001 | 04:48 PM
Pete92TA's Avatar
you can check my pictures on my site of my 92taconv I have 2 12's in the trunk. This would probally be a little much for you, I would say try a good bass tube from JL or something. You could mount it deep in the trunk and remove it easly if you needed the extra space. I just took my front seats out to be redone no space under there. The tube should give you enough to make you happy. http://sites.netscape.net/bulldogfrazier/stereo
http://sites.netscape.net/bulldogfrazier/homepage
http://www.fracoinc.com/
Keep your ride shinning with pride
Old Jan 30, 2001 | 07:18 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Under the seats is totally out of the question. Not nearly enough room. I'm not a fan of free-air, but with a car with an actual trunk it will certainly be a better option than it would be in a coupe. A free-air sub would be the least obtrusive, but a single sub in a small box would give the best sound. Just don't expect miracles with the top down.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jan 30, 2001 | 08:36 PM
MIKES 88GTA's Avatar
A freind of mine had an RS Vert a few years ago, he had a Bazzooka 8" bass tube in the trunk in that stupid hole but ti sounded great!!! Bass with the top up or down.He had one that came with a built in amp.
Old Jan 31, 2001 | 02:20 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
No doubt, a Bazzooka tube will give you justice. The only recomendation I'd make is replace the stock woofer. It can't really handle too much power. I put an MTX Thunder 3000 in, and I'm really satisfied. And that's with a cheap Power Acoustic amp.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Jan 31, 2001 | 08:31 PM
Pete92TA's Avatar
What ever combo you do you should be able to get good bass top or down. Mine still thumbs pretty good with the top down.
wanext
Oct 6, 2015 12:18 AM
Makaveli
Car Audio
Feb 25, 2001 03:46 PM
Sweet_85_Bird
Car Audio
Jan 18, 2001 12:57 AM
86V6
Car Audio
Jan 6, 2001 06:07 PM
junkyarddog
Car Audio
Nov 27, 2000 02:15 PM
