Time to update the infotainment system
Old Apr 4, 2019 | 12:33 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
So I've debated doing this for a while, so I decided to give it a try. I'm putting in a Android head unit.
I've ordered a 3d print of the 2din bezel but it will not be here until this weekend. It will not have the gaps at the sides like the 1.5 din bezel does. And since the radio body is a single din it fits well in the pod.
Here is a test fit. I want the screen flush so I will make a mount that sits the radio deep into the pod.
Old Apr 4, 2019 | 02:36 PM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Time to update the infotainment system
definitely gonna follow this thread... Are the screen and head from different manufacturers or is that a system?
Old Apr 4, 2019 | 04:37 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
It's a single unit, but the screen is removable so you could mount separate.
Amazon Amazon
Old Apr 4, 2019 | 04:39 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
I've seen people use raspberry pi and a screen and cobbler them together. This is easier.
Back in 99 I had a mp3 player in the car... As in a lcd, track ball, and a old computer tower in the trunk... Man how tech has improved.
Old Apr 5, 2019 | 10:16 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
3d printed part came in, you could almost use as printed. This is the 2din version
Old Apr 5, 2019 | 10:37 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
That looks great.
I'd love to do this. If you can just get a durable, piano black finish for the background, and find a way to reproduce the grid, it would look like O.E.
Old Apr 5, 2019 | 10:46 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
They guy that designed the 3d printed sketch that I used has made it look almost 100% stock https://www.thirdgen.org/forums/car-...vement-3d.html he has the templates to have the squares cut out and you can sand and paint it to get the gloss black finish.
But my car is far from OEM (LS1, auto converted to a T56, leather seats and console from a 4th gen, custom made door cards and headliner -- non of which are stock colors (they are all greys though) I'm actually thinking soft touch coating on it if I can find a small enough can as a gallon of the stuff is a few hundred dollars.
Old Apr 6, 2019 | 10:56 AM
LT1/TA's Avatar
Car: 88 Sport Coupe
Axle/Gears: 4.56
That looks sharp,I just installed a 2DIN dvd/cd unit in mine with a 3D printed bezel.
I did not finish mine,so far I just left the printed rough finish.
Old May 19, 2019 | 10:54 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Not quite done yet. These Android radios have their quarks but as long as you accept that the work pretty good.
So full list.
Joying radio
A 12vdc USB hub
USB obd 2 scanner
Dash cam fed into radio
Backup camera
3d printed bezel
Wireless steering wheel controls... Debating if I want to recess those into the center cover.
4th gen console not that matters.
The Bluetooth obd2 scanner and the radio was flakey, the phone works fine. The USB hub gives more ports and fast charging to the phone.
Fits nicely where the old cruise and speedometer buffer lived
4th gen console works well with the t56
Without bezel
Sitting in place still need to make brackets to mount it
Torque working with the USB obd2 adapter. Only good if LS swapped or other obd2 setup.
Trying out the non lumbar power 4th gen seats
Old May 24, 2019 | 01:41 PM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
How's the durability on the spring clips? I've been printing these for awhile and found that they can break easily depending on the orientation of the print. Haven't bothered to check the commercial services when i already have my own designs.
I haven't figured out how to get the piano black finish yet, but the grid can be printed easily enough.
rockstar08
Car Audio
55
Apr 7, 2019 09:27 PM
justme
Nov 23, 2002 09:52 AM
nicksL98
Jun 21, 2002 11:34 AM
