JBL 6421F 4x6 fit in 88’ Firebird dash?
Old Nov 1, 2021 | 08:44 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Like the title says I’ve been looking at replacing front speakers and crutchfield claims these fit, I know the Firebird has tighter clearance in the dash than the Camaro on the driver side. I’ve been reading lots of threads but haven’t found an answer. I know the Kenwoods fit but would like to run JBL front and back if possible but I don’t want to hack up anything to make it fit.
Old Nov 1, 2021 | 10:56 PM
PonchoGTA's Avatar
Car: 1989 Pontiac GTA
Engine: 383 ci
Transmission: M29 T56
Axle/Gears: 9 bolt/3.27 gears 😫
Re: JBL 6421F 4x6 fit in 88’ Firebird dash?
I’ve got the JBL GTO6428’s in the dash of my 89. Had to do a little tweaking and the grilles just barely touch the tweeter. Maybe compare the depth specs to the model you’re considering.
Old Nov 2, 2021 | 09:49 AM
Engine: 5.7 L98
I’ve been looking over specs and can’t get as much info as I want. I really don’t want to get this apart and have to return something that doesn’t fit if I don’t have to. Might just go with Pioneer because I know from reviews they drop right in, I’ve used them in the past in other cars with good results but I’m not a big audio guy.
Old Nov 2, 2021 | 05:27 PM
Kincer's Avatar
Car: 1989 Trans Am
Engine: 305 H.O. TPI
Transmission: Auto 700R4
Axle/Gears: 3.42 posi
According to Crutchfield they fit without modification
Old Nov 2, 2021 | 05:31 PM
Engine: 5.7 L98
I spoke with them today and they said the same, I am inclined to believe them at this point. I just worried because of the age of the car and the difference between the Camaro dash set up that the details might slip through the cracks with age.
Old Nov 2, 2021 | 05:38 PM
Kincer's Avatar
Car: 1989 Trans Am
I think you'll be golden, I used to do a lot of car stereo installs on the side and they never steered me wrong, never had to modify anything, their directions are spot on and included, as well as adapters and such.
Old Nov 2, 2021 | 08:03 PM
Engine: 5.7 L98
They really do seem to make it easy. Will likely order them up soon, maybe make it a winter project.
Old Nov 17, 2021 | 07:58 PM
Engine: 5.7 L98
I wound up going with the JBL 6421F and the JBL Club 9632. I had to go with the 9632 as the other was sold out but got a Black Friday discount on the more expensive speaker and was only a few dollars more than the other ones.
For those curious the 6421F fit the Firebird dash speakers, the driver side was tight but with a slight twist it went right in and worked great without having to bust the dremel out. Passenger side went right in with no issue.
The install kit and instructions Crutchfield sent made the install a breeze, easy connections with no splicing. Can’t wait to really break them in next Spring, they already sound great.
Carlos773
Jan 24, 2020 06:11 PM
FireDemonSiC
Car Audio
35
Dec 4, 2009 02:28 PM
Swigbeast
Car Audio
Nov 4, 2009 02:56 PM
91greenbird
Car Audio
Jul 21, 2006 12:38 PM
TELLEZ
Nov 5, 2000 02:28 AM
