What ohms for 1988 gta UQ7? Current setup in thread
Old Aug 24, 2023 | 08:34 AM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
I had my head unit rebuilt, stock amps
What speaker and subwoofer ohms should I be running with the UQ7 setup? Currently sitting in my garage are
4x6 front Kicker DS 30watt rms @4 ohms
4x6 rear Kicker DS 30watt rms @ 4 ohms
4" Goldwood sound 204/8s subwoofer 70watts rms @8 ohms
Want to make sure they are actually going be be a good sound before I install.
Old Aug 24, 2023 | 02:30 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: What ohms for 1988 gta UQ7? Current setup in thread
for the stock UQ7 system Fronts should be 10 ohms rear 4 ohms and the subs 4 ohm I currently have fronts and rears at 10 ohms and stock 4 ohm subs.
I had read that it's ok to go from 4 ohms to 10 but not 10 ohms to 4,I forget where i read it ,I don't know how true that statement is,but my radio sounds great with the front and rears with 10 ohm speakers.I thinks it all has to do with the stock amp,not sure.
Good Luck with your build.
Old Aug 25, 2023 | 10:17 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
U can use 8 ohm instead of 10 ohm speakers, but cannot go from 8/10 to 4 ohm speakers. I have the stock speakers in my '84 T/A & sounds ok to me.
Old Aug 25, 2023 | 12:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Originally Posted by mantaguy
for the stock UQ7 system Fronts should be 10 ohms rear 4 ohms and the subs 4 ohm,......................
The factory head unit has 2 AMP chips; 1 chip that powers the 10 OHM front and 4 OHM rear 4x6s on the LEFT, & 1 chip that powers the 10 OHM front and 4 OHM rear 4x6 on the RIGHT. The 2 4 OHM Subwoofers are powered by the UQ7 Subwoofer AMP.
Old Aug 28, 2023 | 06:45 PM
Engine: 5.7 L98
Axle/Gears: 3.77
The subwoofers are a bad fit for the subwoofer hole. Anyone know of some subwpofers that will mount to the box mount spots?
Old Aug 28, 2023 | 07:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
I'M not 100% sure ,but I think DynoDave may have tried a different size sub,Check with him,DynoDave,he has a whole thread about his.
Old Aug 28, 2023 | 09:45 PM
John in RI's Avatar
See post # 25,......
https://www.thirdgen.org/forums/car-...r-upgrade.html
Old Sep 1, 2023 | 10:07 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I ended up repairing the foam surrounds on my factory speakers. As that worked, I never did try the aftermarket options.
https://www.thirdgen.org/forums/memb...ml#post6019018
Old Sep 19, 2023 | 06:02 AM
Engine: 5.7 L98
Axle/Gears: 3.77
I'm still on the hunt for some replacement subwoofers. Saw someone recommend fiero speakers replacements from Rodney Dickman. They don't have any.
I don't have my originals because sometime during its life someone replaced them with 6x9s. So kinda at a dead end.
Old Sep 19, 2023 | 11:33 AM
John in RI's Avatar
There's a couple other potential replacement speakers listed by members in that thread I posted,........ read thru that thread for tips.
Old Sep 19, 2023 | 11:36 AM
John in RI's Avatar
Another potential replacement :
https://www.fiero.nl/forum/Archives/...-2-097104.html
Old Sep 19, 2023 | 11:52 AM
Buddy's Avatar
Car: '87 FIREGOOSE!!!!
Not listed on the site, I believe Kee Audio has a package for this.
Old Sep 20, 2023 | 10:13 AM
John in RI's Avatar
Tang Bang speaker and SB ACOUSTICS speakers both appear to be available,.....
TangBang W5-1138SMF
https://www.parts-express.com/Tang-B...Impact&irgwc=1
SB ACOUSTICS SB12PFCR25-4
https://solen.ca/en/products/sb-acou...midwoofer-4ohm
Old Sep 20, 2023 | 12:30 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
is there an aftermarket amp that can be used with the UQ7 subwoofers? i have two factory UQ7 amps, but neither one seems to be working. wondering if i can use something modern instead.
91greenbird
Car Audio
May 20, 2006 11:58 PM
JeffD
Car Audio
Sep 15, 2005 08:21 PM
Eric 97 Z28
Car Audio
Feb 2, 2004 03:14 PM
GCFBA
Car Audio
Oct 25, 2002 09:33 AM
PimpRod92RS
Car Audio
Jan 5, 2002 08:24 PM
