Cant get rid of engine noise in speakers
Old Mar 3, 2002 | 10:37 PM
zee28's Avatar
Car: 86 iroc
got the amp in ,hooked up and I have this engine whine in the speakers that changes with rpm.I have moved the ground 3 times,all in the cargo area,the latest being a screw threw the metal,cleaned to bare shiny metal.Im using 8 ga for ground and power and amp is 200 mounted to a box with 2 woofers.I have moved the rca cables all around and they are now on the seats running right down the middle of the car ,not near anything.The power cable was by the dist.so I moved that and no luck.This noise has not changed at all in moving the grounds which tells me its something else,maybe the amp?It is new.Sounds great except for this noise and when I turn the key on and off I hear a popping in the speakers.I also replaced the ground at the battery to the body.thanks
Old Mar 3, 2002 | 11:32 PM
Omar's Avatar
Use some muting plugs and plug them into the RCA inputs of your amps. Turn on your headlights, and start the car. Does the noise still exist?
If so, the problem is in the amp, speaker wires, or speakers.
If not, the problem is in the deck or the RCA cables.
Old Mar 4, 2002 | 07:18 AM
zee28's Avatar
Car: 86 iroc
I guess I can pick up muting plugs anywhere?Do they go in the amp only or from the amp to the deck?I know nothing about this stuff. thanks
Old Mar 5, 2002 | 09:54 AM
riz75's Avatar
i had the same problems and it was the sh*tty crossover that i had. as soon as i took it out all of the humming and popping stopped.
Old Mar 5, 2002 | 10:47 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Yup... I had a POS Pyramid crossover in an old system. All sorts of whine.
Zee... what kind of amp do you have?
Old Mar 5, 2002 | 10:48 AM
riz75's Avatar
that was the same crossover that was making the noise for me
Old Mar 5, 2002 | 12:09 PM
zee28's Avatar
Car: 86 iroc
ah...pyramid.So this thing is crap or what.Its a proplus 240 I think,cost me $55.new.I wasnt looking to spend alot because I didnt need big sound.So I guess this was a bad choice?can I atleast use it for what its worth and get rid of the noise.When you say crossover,isnt that in the speaker,or on the way to it?What can I do besides buy a better amp?
Old Mar 5, 2002 | 12:41 PM
riz75's Avatar
the crossover gets wired between the source (radio) and the amp. when you have component speakers the crossover will be between the speaker and the (amp or radio) depending on your application. there are gadgets you can get to lower the whinning noice comming out of your speaker, but it might lower the sound quality. try wiring another amp in just to see if that is your problem (go to a stereo shop or a friend with a spare amp). if it is your amp then i would definitely recommend getting another (quality) brand amp. if your funds are low then try ebay. that's where i bought my (memphis) amps brand new.
riz
Old Mar 5, 2002 | 01:18 PM
GndPrx's Avatar
See my reply on the amp grounding thread.
A "muting plug" is basically an RCA end with the tip and outside shorted together to form a loop.
You may be able to find a set of these at Radio shack, if not you can make your own from an old set of RCA's or a cheap set that you cut up.
Old Mar 6, 2002 | 10:57 AM
fast1980camaro's Avatar
wires
you must make sure you pwere wires and you rca wires going to your amps arnt close together, run them on opisite sides of the vehicle
Old Mar 6, 2002 | 11:29 AM
zee28's Avatar
Car: 86 iroc
again,these wires are not near each other.
Old Mar 7, 2002 | 12:42 AM
FiReBReTHa's Avatar
same sheet here too!
dont say amp, i have a JL 300/4
i think it could be ALTernator....
im swapping out head unit soon, so ill see then...
Old Mar 7, 2002 | 11:09 AM
Jim85IROC's Avatar
Pyramid is the benchmark by which all other crap is judged. You can use the muting plugs like GndPrx mentioned, and that will confirm that it's the amp. As usual, you get what you pay for. If you're on a budged, look at amps from companies like Pioneer, Kenwood, etc. The stuff is less expensive (and much less powerful) than Rockford and Kicker type stuff, but at least you're getting your money's worth!
theshackle
Sep 17, 2020 08:26 AM
Reddeath210
Oct 6, 2015 08:20 AM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
