NEED HELP FAST!!!!
Old Nov 22, 2001 | 04:02 PM
OldBlue's Avatar
NEED HELP FAST!!!!
ok im isntalling my head unit in my car, I hooked all the wires up right, ( red wire on harness to orange factory wire , Yellow to yellow, and then the ground ) Right now the deck will eject CD's but the face wont come on. BUT if I hook the red wire up with the yellow wires it comes on. Is the red a constant or a memory? How can I fix it so it works right? I dont wanna ahe to go and reset all my setting everytime I get in the car, thats a bit of a pain in the *** , do I have to run a wire from the fuse box withg a pig tail/ inline fuse or what? I need to get this done in an hour or so cuz I hae to leave for a dinner. Anyhow thanks for any help.
Old Nov 22, 2001 | 04:06 PM
OldBlue's Avatar
ttt
Old Nov 22, 2001 | 04:38 PM
OldBlue's Avatar
come on guys anyone?
Old Nov 22, 2001 | 04:40 PM
deadtrend1's Avatar
hey, well, you radio ejects cds without the ignition turned on, so im wondering if your igniton is on when you eject the cd. First thing is to never just match up colors from the radio to the factory, they are 90% wrong half the time. Secondly, get yourself a nice 12v tester. Use that to find out the power and ground. It looks like a little pointy screwdriver, and lights up when you complete a circuit. I used that and within 2 min, i had power to this dudes headunit. I got info in my homepage.
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
Old Nov 22, 2001 | 04:53 PM
OldBlue's Avatar
well Im hooking it up the same way as it was in my camaro, in the camaro I did have to run a wire from the fuse box. I ahve the 12v tester I use those alot
Old Nov 22, 2001 | 05:35 PM
GndPrx's Avatar
Yellow is constant, Red is switched (on with ignition), Black is Ground
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Old Nov 22, 2001 | 05:55 PM
nagga's Avatar
uh Red is constant and Yellow is ignition, also if u cant find good wires, unbolt your steering column and pull out the harnesses at the end of it, theres a THICK pink wire(ignition switched) and a THICK red wire(constant 12v) splice into those and make sure u use fuses at both of those wires so u dont have a melt down or your electrical system, that would be a real bummer
Old Nov 22, 2001 | 06:24 PM
un4givin89's Avatar
By a freaking wiring harness, its 15 bucks at best buy and will save you alot of hassel, and make it 1000x easier when you get a new heqad unit down the road. Second there is no stock memory wire, trust me. I had to run mine to the ACC fuse. (Acessories)
un4givin89
Old Nov 22, 2001 | 06:55 PM
GndPrx's Avatar
<font face="Verdana, Arial" size="2">Originally posted by nagga:
uh Red is constant and Yellow is ignition, also if u cant find good wires, unbolt your steering column and pull out the harnesses at the end of it, theres a THICK pink wire(ignition switched) and a THICK red wire(constant 12v) splice into those and make sure u use fuses at both of those wires so u dont have a melt down or your electrical system, that would be a real bummer</font>
My appology, I was refering to the wiring harness on the aftermarket deck. On aftermarket harnesses, yellow is always constant, red switched, black ground, blue remote, orange or brown illumination or dimmer
Most people should be using a metra or similar harness rather than cutting off the original harness. That is just bad form and will bite you or whomever buys your car in the a$$ down the road.
Carl
CarAudio Resources
Old Nov 22, 2001 | 07:30 PM
OldBlue's Avatar
I would love to use a harness, but unfortunatley the guy who had my car was a dumbass when it came to stereos, he even cut the antenea off instead of just pulling it out of the back of the deck. Go figure. the IGN. Power is working, So Im gonna runa constant with a in line fuse from the fuse box. that shoudl take care of it.
Old Nov 22, 2001 | 08:11 PM
deadtrend1's Avatar
There is a memory wire, i used a harness on my firebird, and on my friends 89 bird and the memory is there.
-LO3 305 TBI
-5 speed
Old Nov 22, 2001 | 08:13 PM
deadtrend1's Avatar
crud, i ment to reply that with a quote from un4givin89. Not to prove im right or to bust your chops or nothing. i did 3 thirdgens with a memory wire, sure yours isnt disconnected or anything?
-LO3 305 TBI
-5 speed
Old Nov 22, 2001 | 10:48 PM
OldBlue's Avatar
I jsut ran my constant from the radio part of th fuse box since there insnt a fuse that goes there, had to do the same thing on the camaro.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
