Firebird Hood Scoop
Old Jun 20, 2001 | 12:37 AM
jrusselltc's Avatar
Firebird Hood Scoop
I have a 1987 Firebird Formula with the factory hood (and scoop with the opening facing the driver). If I were to remove the plug, what modifications would I need to do to the carb?
Old Jun 20, 2001 | 02:31 PM
84TransAm's Avatar
Nothing. You can get a lid for a 1982-1984 Firebird that had the functional ram air at the dealer, this has a hole in the lid with a gasket around it. Then you can run a hose to the hole.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
Soon: Edlebrock Intake & TES
Old Jun 20, 2001 | 08:33 PM
jrusselltc's Avatar
If I opened up the plug, would it hurt anything? I would allow more air to go into the carb right? Also, would an airfilter without the pan work, the one that bolts on the carb?
<font face="Verdana, Arial" size="2">Originally posted by 84TransAm:
</font>
Old Jun 21, 2001 | 08:41 PM
84TransAm's Avatar
If you open up the scoop, then it might help in cooling the engine bay down a bit. However, you should probably find some way to close it when it rains. (I use packaging tape, who cares what it looks like if it works, right?)
Just buying an open element is probably the best airflow solution you can do. Summit sells a chrome 14"X3" drop base cleaner w/ filter for $20. That would be a cheap way to go.
--Steve S--
Old Jun 23, 2001 | 11:03 AM
Jims83TA's Avatar
I have the functional hood scoop on my '83 TA. It has the hole that fits around my carborator, and wires connected to it. I think it reacts to when I press the gas pedal. Well, any ways, look on ebay. I saw somebody selling this piece for $9.99. They said it would fit the '82-'84 powerbulge hoods as well as the ones on the 87 and up formulas.
Old Jun 26, 2001 | 03:34 PM
Damon's Avatar
Jim's right. The factory piece opens up the passage from the scoop to the air cleaner assy. when you go to WOT. It's actually a little electrical servo that opens the flap. The majority of the "guts" are part of the special Firebird air cleaner assy. but there's also a molded air passage that connects between the scoop opening and the top of the air cleaner. The air passage is bolted to the hood and mates with the air cleaner via a rubber gasket as you close the hood.
Old Jun 28, 2001 | 09:19 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
For another way to make the bulge functional, check out the 'tech' link in my sig for an article I copied from PHR several years ago. They ultimately gained 18 hp at the rear wheels using it.
Pete
Pete's Place
HiOutput Tech Page
83 SC
originally a V6...now
206+k mile LG4/5-speed
14.935@94.14
Old Jun 28, 2001 | 11:48 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Hey,
I opened up the scoop on my 83, my sugestion is to get a k&n filter lid it cost about 50 but it is worth it in the long run, it's working great on my car. even thought i have a VaraJet.
Chevy 2.8L, k&n filter lid, Headers Soon!!!
colton_carlson
Mar 8, 2019 12:21 PM
deracer
Apr 11, 2016 12:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
Randomtask2
Aug 13, 2015 01:57 AM
