which Edelbrock carb to get
Old Nov 5, 2002 | 08:00 PM
84MaroZ28's Avatar
i have a stock 305 l69 ho engine, my q-jet hasent been doing so well, so should i get the 1405, or 1405 (elec. or man. choke), do i need to buy any kits
iv tried a search
Old Nov 5, 2002 | 09:13 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
If you are going to go to an Edelbrock..you will need to get a non CC distributor...remove or at least unplug the computer,among other things to get it to run good.Do you live in an area that requires emissions testing?If so rebuild the q jet.
Old Nov 5, 2002 | 09:55 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
you would also have to rig a switch to lock up the TC in 3rd and 4th..
Old Nov 5, 2002 | 10:11 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
Take into consideration what the first two replies have said. If you are determined to do the swap and properly remove the computer, replace the distributor and address the torque converter issue, then I would think that the model with the electric choke would be best. I just spliced into the existing choke wire for the Q-Jet. You would need to get a adapter to mount the squarebore Edelbrock on a stock spreadbore manifold. But since you will have the dsitrbutor out anyway, you might consider an intake swap if $$ permits and that would eliminate the need for an adapter. The suggestion to rebuild the Q-Jet is a good one. It would probably be the least hassel. Anyway, hope that helps.
Old Nov 6, 2002 | 10:36 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Like they have said.
Also, if this is a daily driver, I'd go with an electric choke. Might get tiresome pullin that cable all the time.
Old Nov 6, 2002 | 11:21 AM
84MaroZ28's Avatar
but im pretty sure the 84 models didnt have computers......???
Old Nov 6, 2002 | 11:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Unless you have an export version LG4, you have a computer, even in 1984.
Old Nov 6, 2002 | 03:43 PM
84MaroZ28's Avatar
and one more question, how come they dont make Chips for 82-85 camaro's??? thats why i thought its non cc
Old Nov 6, 2002 | 05:10 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Before I pulled my computer I had a Hypertech chip in my '82. They make them, but since those years are getting old they might not advertise them as much. From what I understand all L69's had computers so you will have one unless someone already yanked the computer before you got the car.
Old Nov 13, 2002 | 07:51 PM
Blueirocz28's Avatar
Jegs has a special right now 109 dollars and you get all the gaskets needed for an intake swap and a Edelbrock Performer Intake, I think that was the model offered.
codeysabatini
Nov 10, 2015 04:07 PM
sreZ28
Oct 22, 2015 08:21 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Scorched1984
Sep 15, 2015 03:42 PM
WickedBowtie
Sep 11, 2015 11:24 PM
