Cant stall the engine by leaning the mixture
Old Dec 29, 2003 | 06:36 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I tried turning the idle mixture screw all the way in..Vacuum leak?The brake booster is not working either..
Daz
Old Dec 29, 2003 | 05:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the motor still runs after turning in all the idle screws all the way, the motor is getting fuel from somewhere other than the idle discharge ports/ idle circuit.
Bown/ leaking power valve diapharam, dirt stopping the power valve from seating at idle, {get a fuel filter) bad metering block gasket. ( loose fuel bowl screws)
are the usually suspects.
Other causes are flooding (fuel dribbling from the main
venturis at idle) (dirt in fuel inlet needle and seat,{get a fuel filter}
bad float, high float level)
Did the engine backfire or spit back throu the carb recently?
Daz, you seem to have a lot of trouble with that carb.
Old Dec 29, 2003 | 09:26 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
This is a different one..Its a new 1850 Holley from Rod that Im using on the wagon..Im getting a vac gauge tomorrow to help me better
Daz
Old Dec 30, 2003 | 08:32 PM
F-BIRD'88's Avatar
Oh we're talkin' about the new racin' Wagoon...
Old Jan 1, 2004 | 10:17 AM
F-BIRD'88's Avatar
Happy new Year Daz!!!!
Old Jan 1, 2004 | 12:25 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
lol Happy New Year Russ...lolol..So are you gonna answer my question or what?..lol.. Hurry up or this would get locked
Daz
Old Jan 1, 2004 | 06:20 PM
F-BIRD'88's Avatar
I did.....
Does it have a fuel filter?
Old Jan 2, 2004 | 08:08 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I did.....
suuuuuure
DAz
Old Jan 2, 2004 | 08:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
do you have the throttle stop screw so far in that perhaps its off the idle circuit?
Old Jan 2, 2004 | 09:12 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
No the throttle stop is not all the way in..In fact its only less than a quarter in(or less)..It also could be related to this
my other post
Daz
Old Jan 2, 2004 | 05:20 PM
F-BIRD'88's Avatar
what is the ignition timing at idle while in neutral an while in gear. What happens when you unplug the vacuum advance? On what vacuum port is the vacuum advance plugged into?
If its plugged into full manifold vacuum it will idle high in neutral.
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
