best quadrajet replacement
Old Feb 28, 2004 | 05:13 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
whats the best carb to swap in to replace the stock q-jet? On a stock a engine.
Old Feb 28, 2004 | 06:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A stock q-jet.
Old Feb 28, 2004 | 07:08 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Yeah ive read that she should be adequate. Ive also read they are a pain to learn. So maybe you can help diagnose whats going on and give me better direction as to whats going on.
The car seems to idle ok but it seems as if i have to give her the gas pretty hard to get her to go (then it seems to get the gas all at once and floods out) in any case it cuts out.
This may be unrelated but the choke got stuck open the other day. The car was sitting for 5 years or so before my purchase back in october. I have just now been able to really work on her, and seeing as how its still not yet spring i dont know how often i will be able to until it warms up.
Can you give me a few pointers on how to clean it up (with carb on the car) possibly if that is the problem.
VacuumIssue?? Possibly some hints on tips of where to look for vacuum leaks? Im not too familiar with cars but im big on trying to do as much as i can myself so i can learn.
Also on an on related matter i think the cat has died, cuz it wasnt smellin to healthy, but i dont know if that would make the engine cut off after giving her gas.
I must say you have been very responsive in prior posts and i appreciate your help
Old Feb 28, 2004 | 07:36 PM
DauntlessZ28's Avatar
Car: 1984 Z-28
Engine: L69
Transmission: 700-R4
I'd heard that once a cat dies, driveability/starting issues become a problem. If you've got a bolt-on cat, then it might be easy to take it off and just check out the inside of it to see if it's clogged. Then again, taking it off might not be so easy. My car had spent a lot of its life in Indiana (before I bought it), and all the snow and salt pretty much welded the bolts to the flanges. I tried to unbolt the cat when I was putting my headers on; the bolts didn't budge AT ALL. We used an impact set to 650 ft/lbs and broke a u-joint; the bolts were that enfused. Maybe you'll have better luck than me.
Checking for vacuum leaks is easy. Just start the engine and let it idle normally. Use a can of carb cleaner and spray around the base of the carb and the intake manifold near the cylinder heads. If you notice the engine stumble or the rpms drop real low, you've found your vacuum leak.
You can also use the carb cleaner to clean out the carb while the carb is still on the engine. Just spray it down into the primaries and secondaries. Start up the engine, and while the engine is running spray a little more cleaner down the carb. Once you get it running (as in, being able to feed it fuel without it dying), you could try running some fuel injector cleaner through the gas to help clean out any more crap that might still be there.
Since you're not too familiar with cars, I'll go ahead and tell you that you can do these things without doing any harm to the engine (if a lack of experience leads to a confidence problem). There's a lot of stuff I don't do because my confidence is low simply because I have little experience working with engines. It's good that you're eager to learn, though. Knowledge is power.
Old Feb 29, 2004 | 01:21 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
The car idles "ok" in park and if you hit the gas in park you can rev it up and she doesnt shut off.
but if you put it in gear and give her gas she'll die...what causes the difference from when shes in park and when the engine actually has to pull the load?
am i on the right track with it being a carb related problem?
Old Feb 29, 2004 | 02:23 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
Vacuum leaks cause the engine to idle fast. Spray the outside of the carb with WD-40 to keep the choke from sticking.
Might need new Cap/Rotor, Spark plugs, and O2 sensor after sitting for 5 years. Carbs get blamed for a LOT of ignition problems.
Old Feb 29, 2004 | 02:31 PM
Car: 1984 Z-28
Engine: L69
What about any fuel that's been sitting there for 5 years? Fresh fluids might be in order too?
Old Feb 29, 2004 | 02:38 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
all the ignition crap (plugs,wires,coil,module,cap & rotor) is new, replaced that. gas is fresh.
o2 senser hasnt been replaced...(suggestions, tips, how tos ?)
What exactly should the idle speed be on an lg4? it does idle high at start up for a while but it seems to simmer down after it warms up for a while.
Old Feb 29, 2004 | 03:01 PM
Car: 1984 Z-28
Engine: L69
it's supposed to do that. once the engine reaches operating temperature, it goes from fast idle to normal idle.
Old Feb 29, 2004 | 03:19 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
how high is normal during this period? and where should it idle once it calms down?
Old Mar 18, 2004 | 03:35 PM
Car: 1984 Z-28
Engine: L69
mine will be anywhere from 1500 to just above 2000 rpm in fast idle (depending how cold it is), and normal idle at operating temp is probably 750 in neutral and 600 in park.
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
armybyrd
Aug 10, 2015 09:23 PM
Fronzizzle
Aug 9, 2015 01:15 PM
