edelbrock carb problems
Car: 89 formula
Engine: 383
Im having a problem when making turns the engine shakes and dies.I stop the car and it will start back up and run fine. I think its the fuel is getting sloshed around and tried raising the floats but it did not help.Is this common with edelbrock carbs if it is what about holleys?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How hard of a turn are you making? What's the float level set at? What's your fuel pressure?
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have had that happen to me before, but only when I was braking real hard and turning at the limits of my tires. Normally even in a hard turn, mine doesn't shut off or stumble.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
At first mine did this too. I lowered the float setting a little from factory spec and installed a fuel pressure regulator. Edelbrock carbs like a steady 6psi fuel presssure.
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
mine does it all the time too. i wish i knew what my pressure was because im running a v6 efi pump split off into a holley regulator. i was running a edelrace pump in my 85 it worked better.
Car: 89 formula
Engine: 383
I didnt get a chance to lower the floats yet where should the drill bit fit under the float the middle or the front edge?Also my mallory regulator sucks every time I start the car its a different psi 5-10 but It could be the 255gph in tank pump.
Edelbrock tuning
As long as you're using a high pressure EFI fuel pump to feed a carbed motor you're going to have problems.
The carbs floats can't handle the pressure spikes reguardless of the regulator used.
get a pump designed to feed a carb. (6psi).
I recommend a Carter P4600HP
No regulator required.
The recomended float setting is a benchmark starting point. I've found that the car runs better with a little lower float setting. Especially around corners.
Car: 89 formula
Engine: 383
Ok this is the deal when I switched to carb it was only going to be temporary till I had enough money for a new EFI wire harness,36lbs injectors,wideband set up,and laptop.Now for me money is real tight and the carb is going to stay for a while but the EFI is going to go back on so Im not hacking up the fuel lines for a carb friendly pump.Are holleys as sensitive to fuel pressure as edelbrocks are?I know the way Im doing this is half-*** but it has to be this way.
You just don't want to crawl under the car.
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
mines the same setup thats what i was gonna do but only lt1 injected. ran tight so the edel carb stays for now. good luck. Thread Starter
Car: 89 formula
Engine: 383
I droped the floats and it didnt stall yet so THANKS Ill see what happens this week.F-BIRD'88 whats with the attitude I never touched a carb before.How was I to know if this was normal or not?I just asked a question!This has nothing to do with not wanting crawling under the car.Being under the car is like a second home I LOVE IT!
theshackle
Sep 17, 2020 08:26 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
