CCCarb to non CCCarb
Car: 84 Camaro Z-28
Engine: crate 350
Transmission: built th700R4
Hi, i just bought a new holley carb and a new non EGR weiand action plus intake manifold for my 84 Z-28 with a 350, my old carb was a computer controlled quadrajet. My question is will i have to buy a new distributer and which one should i buy?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Any non-computer controlled distributor with centrifugal and vacuum advance will work.
You'll also need some way to lock up the TCC in your 700R4.
Engine: 383 Carb
Transmission: 4L60
A search on the transmission board will turn something up, it's been discussed any number of times.
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
TCC Lockup is pretty easy to do. All you need is a vaccum switch(GM P/N 14014519), some vaccum hose, and 18 guage wire. Check out this thread .
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
as for the dist, I just grabbed one from an '84 cutlass or something of the like. a stock non-cc one, then re-curved it with the crane kit, and shimmed the endplay with a mrgasket shim kit... about $50 CAD total, with the crane kit. now I just need a good strong coil.
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
Also, Do not foget the proper linkage and pracket for you 700r4 cable to work on the holey carb.. you don't want to burn it up. The lockup was discussed at length lots of places with diagrams even on how you can go about fixing it lol.
Transmission: 4L80E/4L80E
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
http://www.700r4.com/tech/tcc/index.shtml
Hmm, if you have a 700R4 from 84, then it's prob a series 1 or 2, you might need wiring for inside the pan. Again, this is all very easy to do. Hell, I can do it!
Also, you want to pickup a TV MAde Ez kit from them to make sure your TV cable is set up right, or you WILL lose your tranny. If you have a series 1 or 2 then that might not be a bad idea, i wouldnt go with anything other than series 3.
Every 3rd gen automatic has the brake switch already.
The vacuum switch disengages the TCC when under load in 4th. Not a bad idea, my '84 full-size Chevy van had it from the factory (along with one for the AC).
Car: 88 Camaro
Engine: 310 LG4
The reason they have two kits is because the brake switch has 2 pin outs, and if the second one is in use by cruise control then you use the relay. Or, if the brake switch only has 1 pin out. I myself will be using the brake switch.
Engine: 383 Carb
Transmission: 4L60
Originally posted by 88_Import_Slaye
DO NOT USE VACUUM LINE! That is the worst thing you could do!
Car: 88 Camaro
Engine: 310 LG4
Doh! I meant a vacuum modulator. It's not the best way to control lockup, the vacuum could change and unlock the converter when you need it to be locked up.
Engine: L69
Usually when you have low vaccum you don't want the TC locking up. I've never had a problem with my vaccum switch.
Car: 88 Camaro
Engine: 310 LG4
there plenty of ppl running vacuum modulators that work correctly, I was saying it's not the best way. That's why GM ditched that setup for somethign better.
Engine: 383 Carb
Transmission: 4L60
You can't put a vacuum modulator on a 700R4. The function of the vacuum modulator on an older transmission is incorporated into the TV cable.
Using a vacuum switch (which is an entirely different thing from a vacuum modulator) to unlock the TCC lockup is perfectly acceptable. GM did it from the factory on hundreds of thousands of non-computer controlled vehicles.
Engine: 383 Carb
Transmission: 4L60
Yup.
If you don't mind increased transmission temperature, shortened transmission life and reduced gas mileage you could do without it.
The easiest way to solve the non ccc stuff is to be simple about i.. if you start at one part, just go all the way... replace the 700r4 with a manual transmision. or a th350 / 400 and then you pretty much do not need to worry about it.
For myself.. I have my eyeball on a t-56. And if I can arrange it I will just grab a full corvette off a police auction and gut it out for engine and such. (you can gab vettes at some of those auctions for around 3500 for a 2003 vette.) I really do not car what it looks like as long as the front half of it is not crunched up like crap.
