gas everywhere
Old May 18, 2006 | 10:18 AM
myfast3rdgen's Avatar
Car: Trans Am
Engine: 305 to 350 to 383 to BOOM!!!
Transmission: 5-speed
Axle/Gears: 3.73 10-bolt
gas everywhere
what would cause gas to come out of the carb choke hole thingy on a 750 holley. Like is comes out at a very high rate... I just put a new motor in and it was TPI before and now its carb, i haven't gotten it to idel yet....i put the mallory fuel reg on it and i haven't been able to mess with it b/c i'm running to shut off the b/c gas is coming out of the hole...also i rebuild the carb myself and i still need to adjust it.
Do i have too much fuel press, or is the carb not adjusted right?
Old May 18, 2006 | 10:40 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
the float is hung open. this could be caused by a couple of different things. either there is trash in the needle and seat causing it to hold it open, the needle and seat are messed up/worn out...or you sank the float..that would be caused by a pinhole in the float and it fills up with fuel and sinks.
it could also be caused by too much fuel pressure. do yo have a gauge on it? what is it showing? should be around 4-6psi.
Old May 18, 2006 | 10:42 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
Are you talking about the vent tube. If so you may have a piece of trash stuck under the needle seat, do you have and electric pump or manual pump, and are you running a filter?
Old May 18, 2006 | 06:03 PM
Car: Trans Am
just a filter before the regulator...i think is comeing out of the vent tube i'm no to sure i've never had a carb before...
as for the the needle seat and stuff... how do i adjust them, and where would trash get hung up...
I don't think there is hole in the float b/c it happen the sec fuel got thru the lines, i think i would have taken some time before it fill up the float.
I can't check the press. b/c before i can get over ther it comeing out of the hole already...i'm hopefully going to get someone to sit there a watch it when i get off work...
but untill them thanks again guys i'll check everything out.
Old May 18, 2006 | 06:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you don't have the inlet nut "screens" in place (Holley doesn't call them "filters"), Holley won't honor their warranty.
I have some pics I'll post sometime soon showing why. I had a filter in the line going to the carb, and the "screens" still had junk in them.
Old May 19, 2006 | 09:29 PM
ZEEYAA's Avatar
Car: 1991 Z-28
O.K Try this, take the plastic end of a larger screw driver and whack the adjustment nuts on the bowles, sometimes if a carb sits for a while without gas in it the seat needle will stick because the float is at the bottom putting pressure on the unit and the thing may become sticky, so when the bowl fills up the needle will stick keeping the bowl from rising and cutting the flow of fuel off, try this first I have seen it happen many times and usually will fix it right away, now if its a new carb it may just be you need to set the float level, have you pulled the sight plugs yet.? If not you may also stick a small screw driver in the hole and see if you can move the float if it is still stuck.
Old May 19, 2006 | 11:04 PM
EvilCartman's Avatar
Car: '82 Z28
My carb did the same thing brand new out of the box. Tapped on the bowl and it fixed the problem.
Old May 20, 2006 | 08:46 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Well MYFAST, whats the deal, did that do the trick?
Old May 21, 2006 | 02:29 PM
Car: Trans Am
THANK YOU !!!!
lately i've been getting the dumbest feed back from people, but you two cut the BS and told me what to do....Thanks alot
Old May 23, 2006 | 07:07 PM
ZEEYAA's Avatar
Car: 1991 Z-28
Yeh, me and MW are both Georgia boys, we get it done.....lol. Glad that took care of your problem, and shoot for about 7lb on the street and 7-1/2 when you make some passes. Good luck.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
