Will it work?
Old Jun 19, 2006 | 07:18 AM
ino's Avatar
ino
Car: 87 firebird
Will it work?
I have a 1406 600 cfm holley brand new 4 bbl carb and an edelbrock performer intake manifold. will it work on my stock 87 305 lg4? if so what will i need to make it work? Thanks guys in advanced.
Old Jun 19, 2006 | 08:36 AM
BigDreams92's Avatar
Car: 1992 RS
Engine: Vortec Headed 383 9.6:1
Transmission: TKO600
Axle/Gears: 10 Bolt Posi 3.73
I don't see why it shouldn't. If you are running a computer controlled car you will need to change the dizzy to a HEI set up I believe.
Also, 1406 is a edelbrock part#, you sure you don't mean 4160?
Old Jun 19, 2006 | 09:00 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
you'll have to change the dizzy out for the non-cc hei style, then the computer can go bye-bye.
you will also need to buy a TCC lockup kit from TCI so that the torque converter still locks up in OD.
Old Jun 20, 2006 | 12:37 PM
ino's Avatar
ino
Car: 87 firebird
yes thanks for correction
what is the dizzy that needs to be changed.
Old Jun 20, 2006 | 01:51 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
the distributor.
your stock one is computer controlled, you need an old school springs&weights&vacuum advance style one.
Yer basic mechanical advance HEI distributor. A junkyard one, or a simple one by MSD or something will work.
Old Jun 20, 2006 | 05:23 PM
mw66nova's Avatar
Engine: 7.0L
yep, mine is an advance auto 1979 Chevy Monza w/ 305 replacement distributor, though an accel one through jegs is probably cheaper (comes with coil and stuff too...)
Old Jun 20, 2006 | 05:59 PM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
go to my post b4 you buy TCI kit
https://www.thirdgen.org/forums/tech...converter.html
Old Jun 21, 2006 | 07:31 AM
ino's Avatar
ino
Car: 87 firebird
ok thanks guys
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
