Finished the winter carb project
Old Aug 20, 2006 | 06:29 AM
Dan W's Avatar
What do you guys think?
355 with Edelbrock 750, rpm air gap, ARF 195's and lunati 60104 cam. I used the malory fpr with return line and the 255lph in tank pump that was already in the car. Seems to work ok.
Attached Thumbnails Finished the winter carb project-left-side-motor.jpg   Finished the winter carb project-right-side-motor.jpg   Finished the winter carb project-motor-front.jpg
Old Aug 20, 2006 | 08:24 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Looks good. How's it run?
Old Aug 21, 2006 | 10:03 AM
Dan W's Avatar
I've been playing with the tune off and on when I have time. ... today was the first day I've had a chance to get into it. Was on the autobahn... goes from 70-120 mph in a blink. I'm still playing with the part throttle stuff... I have bog just off idle thats worse when its cold. I assume that its a little lean there. Need to take a look at the transisition slots and make sure they arent uncovered too much. Its acting a bit lean on cruise also.... prob just needs one stage richer on the jetting.
Old Aug 22, 2006 | 07:31 PM
DM91RS's Avatar
Car: 91 RS
Dan is this the car that you used to have TBI on? It's been years since I've seen that website.......
Old Aug 25, 2006 | 02:29 PM
Dan W's Avatar
Yep, same car. The website was on another f-body page and it disappeared a while back. The project has changed gears so many times it makes me dizzy, stock, holley 2bbl tbi, 4bbl tbi, 2bbl tbi, multi-point tbi and now carb. I put the carb on to simplify things and get the car going for a while while I sort out the rest of the car... when all the misc stuff is done, I'm going to go back to the multi-point setup... and when my welding skills get good enough I'll tackle fabricating the headers for the turbo setup.
I'm pleased with the way the carb tunes... I've only done a little work with carbs in the past so this was fun to learn a little more about them. It turns out that the 750 edelbrock carb wasn't the best choice for my application though... my cam is a little big for it and the edelbrock guys said their 800cfm carb would have been a better choice. The 750 is set up for economy they said. Edelbrock suggesed their larger pump nozzle... I think part of the problem is the lean step on the jetting is too lean. It will be a month or so before I'll know... the car is being shipped and I'm heading back to the US tomorrow morning.
Old Aug 25, 2006 | 02:58 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I would LOVE stay in germany for a while and drive the autobahn that would be so cool!
Old Aug 25, 2006 | 11:20 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
that's one clean engine bay my friend!
Old Aug 26, 2006 | 04:29 AM
Dan W's Avatar
Thanks, it was a lot of work and I think the finial product was worth it. When I get some more time, I'm going to hide the washer fluid resevoir and catch can. To make room for the down pipes for the turbo project, I'm going to run a remote brake booster/master cylinder also. I had to kick myself, when I was bleeding the clutch I didnt realize I spilled some brake fluid and it ate the paint under the brake booster. I didnt have time to fix it before the car was shipped.
Old Aug 26, 2006 | 04:36 AM
Dan W's Avatar
You know, it was pretty cool at first but after a while it just becomes normal. My job required lots of air travel and its a 100 or 120 mile trip to the air port... the trip usually takes just over an hour in a rental car like a volkswagon golf or ford focus. The suspensions on the cars over here are set up alot better for the speeds than american cars... If you drive a 3 series bmw or mercedes here, when traffic is light you can cruise at 120 with one hand on the wheel and drink your coffee with the other. I joke that I have as many miles at over 100mph as many race car drivers. Its going to kill me to drive in the states again, 75 mph, ug.
Old Aug 26, 2006 | 10:24 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
looking good! now you just gotta put a real exhuast system on her to allow her to breath a bit better! those edelbrock headers just ain't gonna cut it...
neilb
Oct 4, 2018 12:36 AM
Cleotiz
Jan 6, 2018 08:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Chevy3shitty
Sep 1, 2015 09:22 AM
