carb spacer help
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
carb spacer help
has anybody put on a carb spacer? i bought on and do u just scre the spacer down then the carb to the spacer?
Car: 64 Impala, 86 Z28 Camaro, 00 C5 FRC
?? not exactly sure what you mean about screwing the spacer down...
you will either need longer bolts or longer studs to accommodate the spacer, then put a gasket below and on top of the spacer, and put the carb on top of that. Then just install the longer bolts, or install the nuts on the longer studs.
Engine: 355
do they add any horsepower? i got one for an edelbrock intake to quadrajet carb 1 inch spacer...
Last edited by billybob6110; Oct 15, 2006 at 11:36 PM. Reason: Automerged Doublepost
They can, usually a spacer helps keep the air and fuel mixed together, they also help insulate the carb from the heat of the engine for a slightly denser mixture.
Engine: 355
i put the spacer on and i cant get the fuel line to reach what do i do now buy a new one? or how do i get it to reach?
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
The easiest way would be to install a flexable line from the hard line to the carb. But if you have time and a lil extra cash I would get some stainless line and some AN fittings and make a nice line from the pump to the carb, makes for a cleaning nicer look.
Engine: 355
its only 3/4 inch spacer nothing drastic how will i know if cable wont work?? does it have to be straight that what u mean? so how do i do the flexible hose thing?
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
A one inch spacer may make from 1/2 to 1 horsepower. Not much to notice but the fuel mixes more evenly with the air.
Engine: 355
Car: 91 Camaro RS
Engine: Small Block
The easiest way is to get some 3/8 fuel line from the hardware store(or braided line) run it from the pump to the carb with hose clamps. Since you said you have a carb, you only need between 6 and 8 psi of fuel. I did the same thing on mine.
Engine: 355
can anyone post a pic of there lines from fuel pump to carb? i wanna c different ideas out there... thatnks strokermotor91
Engine: 355
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Engine: 355
