Getting the QJet secondaries to open faster...
Old Nov 2, 2006 | 07:48 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Are there any good ways to get the secondaries open sooner on a QJet? My blower really likes those giant secondaries. I think I could benefit from them opening sooner.
thanks
Old Nov 2, 2006 | 08:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
thanks
It is detailed in Doug Roe's Rochestor carb book as well as How to Hotrod Small Block Chevy's. It basically gives you secondary opening starting at about 1/2 throttle.
Old Nov 2, 2006 | 09:58 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
If you snap the throttle to WOT, and want them to open faster;
-less tension on the AV, but you will have to play with that to keep away a bog (richer rods help offset that as well)
-may need to move your "secondary acc pump" shooters to below the air valve flaps. (see the Roe book for more info on this one)
-cross drilling the secondary enrichment tubes. This is mentioned in a few articles, I tried it, but undid it. In retrospect (and with supervisor42's advice), it'll just let the secondaries pull air instead of fuel sooner, so...
-drilling the restriction in the vacuum break to let it use the secondaries in 3/4sec rather than 2.5sec or so.
If you want the secondaries to come on sooner, ie, at a lower throttle percentage (like fast is saying), that's just bending linkages really.
The vac break one is a good one to try IMHO, search on the forum, i've posted on this, and Lo-tec posted a nice picture of it.
Old Nov 3, 2006 | 10:42 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I see why you refered me to the Doug Roe's book. Kinda tought to explain that one second-hand.
I'm going to try that and enlarging the vacuum break bleed by a tad. I know, a little bit makes a huge difference.
Old Nov 4, 2006 | 03:35 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I got it working fine. All 5 lbs of boost comes on quick. Now I need to make a new accel pump lever for more squirt.
Old Nov 4, 2006 | 04:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
You got what working fine, the blower or the vac break or...?
The lever probably isn't the problem. You can use a different pump itself, enlarge the shooter nozzles, grind down the pump top (to give 3/32" more travel) etc etc. If you move the leverage in too far, you may bottom out. So rather then increasing the Z, increase the radius
Old Nov 5, 2006 | 02:27 AM
Car: Bee-Bowdy
Axle/Gears: fo-tins
I got the secondaries to open sooner. That works fine...
I ground down the pump shaft as well. I read that in the QJet book.
How do I go about increasing the radius? Or for that matter, enlarging the shooter nozzles?
Old Nov 5, 2006 | 03:24 AM
Sonix's Avatar
Car: 1982 Trans-Am
shooter nozzle probably isn't a problem, but that'd be drilling. I'd leave that 'till dead last.
If you have the q-jet book (doug roe) handy, then I refer you to:
Page 128. You drill/bore out the hole for the pump well. Also, opening up the fill hole a tad might be worthwhile, also on the secondary pump bowls as well.
Also see the picture at bottom of page 124.
Damon runs a roots below his q-jet, he should have more detailed info for ya.
I need to get the book "how to hot rod the small block chevy"...
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
racereese
Oct 10, 2015 09:39 PM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
gta892000
Sep 16, 2015 12:37 AM
