Best carb in my case??
Old Feb 22, 2008 | 10:13 AM
jaron's Avatar
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
allright i have a 1983 305, i picked up a 'performance' 350 sbc, its rated with the quadrajet carb and cast iron intake manifold to be 275hp, now i decided to go with the edelbrock 2101 performer intake manifold on the recommendation of the guy who sold me the block, however he refuses to "divulge" what carb would suit it best, so my question if based on usage with the 2101 what carb do you guys recommend to get??
Old Feb 22, 2008 | 11:18 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
Re: Best carb in my case??
Edelbrock 600 or 650 tops. For what your looking to do its the most efficient and reliable street carb for a standard 350 sbc. If you were building a mild to wild 350 I would say lean towards the 650 or step to a nice holley.
I had a e/b 600cfm on a 355 with rpm cam, rpm intake and Vortec heads and ran low 13's with it.
Old Feb 22, 2008 | 11:21 AM
http://store.summitracing.com/partde...HLY%2D0%2D6210
Or, if you can find one, a 69-70 Q-Jet from a 350; carb # 7089202
Old Feb 22, 2008 | 11:23 AM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
hmm thanks guys, i was thinkin about the edelbrock 600-650, i was leaning towards the 650, just to be safe...they're runnin me around 340$+taxes so i think i would go with that, its just that so far whatever i had decided to throw in i ended up changing after reading reviews from the forums, so i decided id ask you guys to see which carb best suited my needs
Old Feb 22, 2008 | 11:40 AM
I think you'll find, that Holley is AHELLUVALOT better carb than the Carter.... better linkage, better fuel line arrangement, better air cleaner fit, runs better, gets better gas mileage, just better period. Well worth the extra couple of bucks, you'll make it back in a few weeks of gas.
Old Feb 22, 2008 | 05:24 PM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
yess....but how compatible is it with the 2101?? wouldnt an edelbrock carb function better with the 2101 than a holley???
Old Feb 22, 2008 | 06:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No way, no how.
The best carb for that 350 engine, with or without the 2101, is the one on your 305 right now.
Old Feb 22, 2008 | 06:54 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I agree with 57, the quadrajet is the best choice, though this is the only carb setup I've ever worked on, it runs great on the street.
Old Feb 22, 2008 | 07:06 PM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
hmmmm interestin.....very interesting, because i doubt another carb would add on anymore HP anyway....so you're thinkin is i should get a new stock q-jet OR rebuild the existing one?
Old Feb 22, 2008 | 07:44 PM
If you still have your stock carb, rebuild it. That will also require your stock distributor and ECM, along with thesensors and wiring that your car came with.
The carb isn't anywhere near being a limit to the performance of the motor you describe.
My suggestion was based on the (perhaps flawed?) assumption that you didn't have that any more.
That'd be the first and best choice. If you HAVE TO replace it, like if you don't have it any more or the rest of the system is so hacked up or missing that it can't be restored, then the other would be the way to go.
Old Feb 22, 2008 | 08:05 PM
five7kid's Avatar
If you still have your stock carb, rebuild it. That will also require your stock distributor and ECM, along with the sensors and wiring that your car came with.
"Toronto, Ontario"
May not be an ECM there.
Old Feb 23, 2008 | 12:35 AM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
thanks a lot for the input .... saves me some $$$'s there....i just ran out and checked....the carb is new (or newly rebuilt) its stilll un-dirty and new....so ill have it looked at but will prolly run the existing one...and plus if it craps out...its right on top..so easier to replace....i was actually considering changing the distributer to a brand new one.....but im thinking that you guys are thinking to stay with the stock distributer??
Old Feb 23, 2008 | 12:52 AM
five7kid's Avatar
Any chance of posting pictures of the carb and distributor?
Stock HEI's often die above 4500 RPMs. The "fix" is an aftermarket module and coil.
If you get another distributor, a good one will run you a couple hundred. I picked up an Accel HEI with Supercoil last September when my 2nd ignition system failed at the track (first failure was caused by getting the MSD wet in the car wash - never figured out what happened to the 2nd one). Oh, the 2nd system was a factory HEI distributor, Crane HI-6 box, and an MSD in-cap coil. The engine pulled to 6200 RPMs with the factory distributor and Accel set-up, just like it did with the full MSD system.
Old Feb 23, 2008 | 01:58 AM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
cool i got a price from karbelt...my parts guys on a distributor .. turns out they want 195$ for a dist. that will be able to hande 300hp and over 5500 rpms....i shld be good with that...i might run the stock dist for a couple of months...but other than that i can see if i can grab some pics of the carb...its kinda tight..shes in storage right now
Old Feb 23, 2008 | 04:38 AM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Also you can modify the stock carb to better handle the bigger engine. There is a sticky at the top of this forum. When I eventually get m 350 swap I plan on sticking with the stock setup myself.
Old Feb 23, 2008 | 04:14 PM
jaron's Avatar
Engine: 305 V8
Transmission: TH200
Thanks a lot for all the replies, i'll go with your reccomendations and stick wi th the q-jet carb, and will most likeley get a MSD dist....im getting the stewart waterpump so i shld be running a pretty sweet setup once shes fully on the road....thanks a lot once again
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
customblackbird
Oct 1, 2015 04:30 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
rjcme
Sep 5, 2015 01:23 PM
