Quadrajet. Decent carb?
Old Nov 27, 2010 | 01:29 PM
  #51
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Re: Quadrajet. Decent carb?
the choke cable kit for the Qjet jc, removes the round black plastic bimetalic spring cover, and simply replaces it with its own round black plastic housing to attach the cable to. hardest part is drilling for the screws to mount it. but it can be done. as for the electrical connection, anything that is hot with key on, but must go off with key off.
Old Nov 28, 2010 | 06:20 PM
  #52
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Yes. Make sure you tap into a circuit that switches off with ignition.
Old Nov 28, 2010 | 07:10 PM
  #53
jchaussee's Avatar
Car: 85 Z28
Engine: 327
Yeah I have pretty much givin up on this thing. Now it " leaks" fuel or something , and quite a bit, when I turn it off. Pretty much sucks. It somehow is in beteem the two sets of " holes" and then works it way around the choke assembly, then puddles up on intake manifold. And it is quite a bit. I blew all around it with my air compressor to try to dry it all up and it was spewing out. Arrgggg
Old Nov 28, 2010 | 10:08 PM
  #54
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
if it's tha 85 carb jc, there's always the truck and back tire option. careful you don't start any fires on your engine. i hope you get it worked out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jerzyperson
Carburetors
Nov 13, 2015 01:07 AM
sreZ28
Oct 22, 2015 08:21 AM
customblackbird
Oct 1, 2015 04:30 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
