383 stroker intake & carb
Old Dec 11, 2011 | 11:09 AM
pete_wright's Avatar
Car: 1982 pro touring trans am
Engine: chevy 383 stroker
Transmission: built TH350
Axle/Gears: ford 9inch 3:63
I am curentley running a 1982 trans AM, I did have a 400ci (but block is cracked) I have just purchased a sbc 383 stroker set up as follows:
383 small-block Chevy stroker motor, 4 bolt mains, Features 10.5-to-1 Keith Black Hypereutectic pistons, GM Pink rods, Clevite bearings, Melling hi-volume oil pump, Prosport damper, Moroso chrome sump, The World Products Sportsman ported iron heads, has 202/160 valves, heavy-duty pushrods, roller rockers and solid lifters and matched springs are part of a Competition Cams 294S kit.
& Hedman headers. Has a built TH350 3:63 gears.
Pleasea advise what would work best: Edelbrock performer RPM air gap manifold and holley 780cfm street avenger carb or Edelbrock Victor Junior manifold, Demon 825cfm carb. Also what kind of horse power & torque do you think would be acheved.
Thanks in advance,
Pete
Old Dec 11, 2011 | 11:47 AM
robg91z's Avatar
Car: 1991 Camaro Z28
Engine: 350ci TPI
Transmission: built 700r4
Axle/Gears: 4th gen rear end
Re: 383 stroker intake & carb
for what would u be using this car for? street and strip or just straight up strip cuz the performer rpm is a good intake all around but the victor junior is more like a high reving intake for top end stuff i think its a 2500 rpm and up and i think the rpm is a 1500 which is better for street and strip in my opinion thats the set up i wanted to do on a 383 i was gonna build but thats just my 2 cents good luck on whatever u choose to go with sounds like it will be a killer TA for sures
Old Dec 11, 2011 | 12:00 PM
I am going to use the Trans Am for street and strip (not a every day motor)
but when the sun is out ive got the option.
Old Dec 11, 2011 | 02:01 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Holley 750; mechanical secondaries.
Old Dec 11, 2011 | 02:29 PM
Cosmik Debris's Avatar
Out of the two intakes you specified I would take the Airgap. I have no experience with either of those carbs so I can't comment on them, my own choice would be for a 650, 700, or 750 mechanical secondary Holley, only because of familiarity with the Holley brand. If you have an auto a vacuum secondary would be an option.
Old Dec 11, 2011 | 04:55 PM
Thanks for your feedback, what kinda bhp do you think this engine will make?
Old Dec 11, 2011 | 05:13 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Depends who did the port work. That could really help or hurt you depending on who did it.
Old Dec 11, 2011 | 05:39 PM
izcain's Avatar
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
Cam specs and head flow numbers would give a lot better guess on what then engine will produce
Old Dec 11, 2011 | 05:41 PM
izcain's Avatar
Engine: 584
Would definitely go with a mechanical secondary carb though
Old Dec 12, 2011 | 04:31 AM
I will see what i can dig out later to find out some more info on cams ect... I will also see if there is any other details about the carbs, I own both these carbs and thought that instead of getting a new one that one of them would work quite nice!!!
I have tryed to attach some pics of the vehicle (hope it works)
pete
Attached Thumbnails 383 stroker intake & carb-peter-wright-007.jpg   383 stroker intake & carb-trans.jpg
Old Dec 12, 2011 | 07:57 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
For a street driven automatic transmission, the dual-plane intake is the way to go. I prefer manual secondary carbs myself, but either would work for you.
Old Dec 12, 2011 | 02:31 PM
pete
If you have those carbs already then you can make one of them work OK I'm sure.
Old Dec 12, 2011 | 03:12 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I agree. I'd get the Holley and grab a trick spring kit for it. That should help some.
Old Dec 18, 2011 | 07:03 AM
Well I have gone for the Edlebrock victor junior inlet manifold and barry grant mighty demon 825cfm carb, car is great and very happy on the road indeed lol !, The next thing on my list is the Ignition has any one got any good recomendations??
Old Dec 18, 2011 | 03:01 PM
I'm glad you ended up with something you are happy with. What features do you want your ignition to have?
Old Dec 18, 2011 | 05:43 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
I believe Holley's website would recommend the street avenger and so would I. The vacuum secondaries work well. My car is similar to yours- 350, Dart iron heads, th350, 3.73 gears, 3500 rpm stall.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
Mickeyruder
Sep 2, 2015 02:45 PM
bdads
Aug 24, 2015 06:01 PM
theurge
Aug 21, 2015 12:46 PM
