ODB need your help
Old Feb 15, 2001 | 03:56 PM
mustangs killer's Avatar
ODB need your help
Which hole on the acell-pump rod assembly will give me the the biggest squirt of fuel. I have an edelbrock 750cfm performer manual choke. It came out of the box in the top hole. Thanks
Old Feb 15, 2001 | 04:59 PM
MikeS's Avatar
The hole closest to the accelerator pump plunger should give you the biggest squirt. You basically want it set closest to the fulcrum of the little lever in order to get the most travel out of the plunger.
Old Feb 15, 2001 | 05:06 PM
The ODB's Avatar
Yes, it's the closest one to the carb body. I had to drill another hole on the bottom lever and step up the squirter nozzles in mine to get the proper pump shot.
What do you have and what kind of adjustment does it need?
ODB
Old Feb 15, 2001 | 07:39 PM
I have a 355. 10.5:1 compression ratio. edelbrock cam Lift at valve: Intake .488 Exhaust .510 Lobe Separation: 112° world product 67cc heads, 350(.030) as i said before the carb is 750cfm edelbrock performer.a torker 2 intake i have also ported the heads intake and headers so they flow great. the tranny is a 700r4 with a 2000 stall converter. i have made a few mods to the valve body. the rearend is 373 posi. The prob. sometimes when I put the gas to the floor it wants to stall for a second and then takes of like a bat out of hell. I figured the accel pump wasn't squirting enough fuel during the transtion. The pump lever has 3 holes when you say the one closest to the carb are you talking about the top hole. and if you drilled a new on was it above the top hole. Thanks. ihope this info helps
[This message has been edited by mustangs killer (edited February 15, 2001).]
Old Feb 15, 2001 | 09:56 PM
The ODB's Avatar
<font face="Verdana, Arial" size="2">Originally posted by mustangs killer:
</font>
Oh yeah, you're they guy with the torker-2 intake. I remember posting about this in a different thread. Get rid of the intake and get a performer-RPM. Swapping intakes will fix you up very well.
Yes the top lever has 3 holes and the top hole is closest to the plunger or carb body. I had to drill another hole on the bottom lever and bend the rod slightly to change the stroke ratio a bit and increase the plunger travel. I also had to switch to a #43 squirter nozzle on my 750.
Some of your hesitation may also be caused by a lazy spark advance curve. What kind of distributor do you run and what is your initial and total timing?
ODB
Old Feb 16, 2001 | 08:55 AM
is the torquer 2 really that bad, and if I do get a rpm performer will i still have enough hood clearce for the air filter. stock hood 91 RS
[This message has been edited by mustangs killer (edited February 16, 2001).]
Old Feb 16, 2001 | 10:13 AM
The ODB's Avatar
I can't answer about the hood clearance.
Yes the torquer-2 is that bad.
Old Feb 16, 2001 | 11:40 AM
ERIC'86IROC's Avatar
I previously posted that my stock hood would not fit with my Performer RPM manifold. I was wrong, looks are very deceiving. It does fit, and with about 3/8" clearance. I am using a Holley carb and Edelbrock 14" drop base air cleaner.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Old Feb 18, 2001 | 01:41 AM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
ODB
</font>
exactly right! ditch that damn NO TOURQRE 2 INTAKE i had it and **** man, it really sucks i know this for a fact nothing but, damn problems you name them i had them!! i finally listened to someone and changed the pos intake to a rpm intake and man you'd love it it has great low end and great well... everything!!! get the rpm man im telling you that intake blows **** !!!!!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 160 (882) heads,.447/.447 lift 222@.050 duration speed pro 327/350hp cam 350 .40 over (356) edlebrock performer rpm intake and a 600 edlebrock manual choke (1405) Proform H.O. distributor slightly revised 700r-4
Future mods comp extreme energy roller cam, world products sportsman 2 heads, msd 6al ignition, billet distributor, blaster 2 coil and a 406 engine is in the works soon!!!!
Old Feb 22, 2001 | 12:44 AM
GOLD85's Avatar
i have a perf RPM and holley, a 14X3 drop base air cleaner clears a stock hood.
when the green flag drops the bull$hit stops
Curent: 350,performer RPM intake ,650dp, 700r4, headers, 3inch exhast
Spring 01: 406, Comp 282 solid cam, 2400 stall converter, every thing else the same.
R.I.P #3
gta892000
Aug 11, 2019 11:16 AM
90Camaro4ever
Dec 22, 2008 07:07 PM
Destructive099
Mar 22, 2007 08:33 PM
prevarications
Feb 6, 2007 11:14 AM
EllisB
May 9, 2004 07:28 PM
