Car at 160F...good?
Old Jul 16, 2003 | 07:44 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Car at 160F...good?
Recently installed 180 stat and new hypertech fan switch. Car was not running hot(ter) than normal prior to install. Now the car is at a consistent 160. Just wont heat up more. do i want the car running at this temp? Its a stock 305 tpi. thanks
Old Jul 16, 2003 | 10:53 AM
MdFormula350's Avatar
if it were me i wouldnt run that low, i use a 180 stat and stock dual fan turn on temps with a manual switch hooked up onto the passengers side.
as far as i am concerned that is too low of a temp, for me to run at least.
Old Jul 16, 2003 | 11:10 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
should i put the 195 stat back in and leave the fan switch the same?
Old Jul 17, 2003 | 09:44 AM
i am alittle confused, not sure how the car can be running at 160 with a 180 stat.
a 180 stat and the fan being on all the time it shouldnt get under 180, are you sure ur gauage is working fine?
Old Jul 17, 2003 | 09:46 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
worked fine before the switch. that thought has crossed my mind. Where is that sensor? How can I test? thanks
Old Jul 17, 2003 | 09:53 AM
i would keep the 180 stat in. and keep the new fan switch in.
the guage sender should be in the drivers side head, between the 1 and 3 cyclinders.
its hard to take a guess where the temp is at on the stock gauges, i just guess myself most of the time. as long as the guage works, i think you should be fine. if u can ask someone around your place to borrown a scan tool just to see what the computers reads as the temp that would be a good way to ifnd out how close ur guage is at.
Old Jul 25, 2003 | 06:05 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
I'm kinda' wondering why you changed it if it wasn't running hot?
GM put the 195 in there to reach a wide range (average) climate and driving conditions. Some folks cliimate or habits make this not the ideal temp. But it sounds like in your case you are an example of the 195 being right..... or at least close to it.
Think of the stat as a range (closed.......rating........open) or as 3 temps not one. Your 180 slid this range downward and cooled your engine too much.
I would put the 195 back in. It sounds like it was correct. Then try another method of reducing the temp (adjustable fan relay) to "slightly" reduce the temp if this is what you desire.
Your goal (which is not obtainable) is to run 195 ALL the time so get as close as you can.
Red 86 T/A 5.0 TPI (LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Plenum ~ Pirelli 245/50/16
~SLP TB Airfoil ~All Else Stock
Old Jul 28, 2003 | 08:51 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I originally put the 180 in because in heavy stop and go traffic the car ran hot consistently. Can I leave the fan switch in and go back to the factory stat?
Old Jul 28, 2003 | 08:55 AM
85TPI400's Avatar
It almost sounds like the hypertech switch is turning the fan or fans on to early, earlier than your stat is opening. Should be the other way around.
Old Jul 28, 2003 | 09:07 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Recommended solutions? Car is only driven in summer.
Old Jul 28, 2003 | 01:52 PM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Sure you can and that's what you should do.
You have 2 choices:
1. Go to a 195 Stat and leave the H/T Switch.
2. Remove the H/T and leave the 180 stat.
The combination of your 2 procedures went from one extreme to the other but the good news is it solved your problem. Changing the stat would seem easier.
If you are unhappy with the results then try the other method.
Still unhappy?
Go to another method like the Derale Adjustable Fan Relay where you can actually vary the kick on temp from 150 to 240. Excellent for fine tuning your cooling system for your own personal driving situation.
Old Jul 28, 2003 | 02:08 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
change the stat it is...the fan switch was a $%&**! thanks
Old Jul 29, 2003 | 06:24 AM
25THRSS's Avatar
Ever consider your gauge might be off? The factory guages are not that accurate and it wouldn't suprise me if it was off by 20 degrees or more.
Old Jul 29, 2003 | 08:57 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
thought about that too...how can i check. I have no diagnostic equipment? Is buying a new temp sesnor reasonable?
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
