Size of Standard/1LE Heater Fan???
Old Jan 18, 2005 | 10:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im doing the ac delete and need a 1le/non a/c heater fan (hampster wheel) but need to know what size the non ac fans are. autozone has them but doesnt konw what part is to the non a/c fans.
can anyone tell me the dimensions???
Old Jan 20, 2005 | 05:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
the non A/C fan wheel is just a tab bit shorter in height. The diameter is the same I believe.
Old Jan 22, 2005 | 08:23 PM
84Zjustme's Avatar
Car: 84 z28
Engine: 355
for ac delete on my 84 z28 the fan and motor are different sizes and you must change them both. I hope this helps. I went to parts america for the fan and back out to pep boys for the motor.
Old Jan 22, 2005 | 09:33 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Hampster wheel: 5 5/8" diameter x 2 3/4" height.
Old Jan 22, 2005 | 11:05 PM
JPrevost's Avatar
Car: 91 Red Sled
The motor isn't different, just the fan cage and resistor block.
Old Jan 22, 2005 | 11:14 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanx lo-tec, that is for the non a/c hampster wheel right?
and 84Z...the motors are in fact different but are interchangable. if you go with the a/c motor though you get another fan setting, HIGH. the standard heater motors dont have that high speed.
Old Jan 23, 2005 | 08:22 AM
Lo-tec's Avatar
Yes, for non-A/C motor.
The motor has nothing to do with fan speed. The non-a/c resistor has 3 speeds, the a/c resistor has 4 speeds. I would put the resistor from your a/c setup into the delete box, then there's no need to cut and splice wires going to it and the stock heater control head will also work. I did this and works great. If you do a search, I think you can change the lens cover on your control head to a non-a/c one without changing the unit.
Old Jan 23, 2005 | 08:49 AM
84Zjustme's Avatar
Car: 84 z28
Engine: 355
see if this works. I took Pics of the swap. The pic was on a 5 mega pix cameraand i had to shrink it down. this is pic of the blower motors.
Old Jan 23, 2005 | 09:23 AM
84Zjustme's Avatar
Car: 84 z28
Engine: 355
these might be better pics. I also used the origional resistor from the ac unit. I didn't get any pics of the resistors.
Old Jan 23, 2005 | 09:29 AM
84Zjustme's Avatar
Car: 84 z28
Engine: 355
sorry pic didn't load
File Type: bmp
Old Jan 23, 2005 | 09:31 AM
84Zjustme's Avatar
Car: 84 z28
Engine: 355
and here is a pic of the fans
File Type: bmp
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
