Hey what do you guys think of this dual fan?
Old Jun 3, 2005 | 07:23 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
I'd like to get better cooling in the summer out here in the desert. I was thinking of an aluminum radiator and this dual fan.
Here is the link.
http://store.summitracing.com/defaul...D42796&NeXID=4
4,000 cfm and universal fit. The universal fit has me a bit skeptical.
Attached Thumbnails Hey what do you guys think of this dual fan?-dual-fan.jpg
Old Jun 3, 2005 | 07:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Universal fit means it's not made to fit anything in particular, not that it will fit anything. From the picture, it looks like it's supposed to mount to the radiator using the plastic screws pushed through the radiator. You might want to find a better way to mount yours.
Old Jun 3, 2005 | 07:54 PM
azvolfan's Avatar
Is there a direct fit dual fan that doesn't cost an arm and a leg?
Old Jun 3, 2005 | 07:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I don't know. The stock setup is about as close to direct fit as you're going to find.
Old Jun 3, 2005 | 08:05 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
The stock setup is the way to go. Score one out of the junkyard, parts for sale section, or ebay. Very easy to wire up, and guaranteed to fit. You can wire it up so both fans come on at the same time. DO NOT use the fan mounting zip tie rig job as shown in your pix. Been there, done that. Takes very little time before you're pulling the radiator to get the holes it will wear in it fixed.
Old Jun 3, 2005 | 09:26 PM
azvolfan's Avatar
Did the Z28's come with dual fans stock?
Old Jun 3, 2005 | 09:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not all of them.
Old Jun 3, 2005 | 11:46 PM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
I bought a Spal dual fan that will suck the paint off the front
bumper....
I made an 1/8" aluminum frame for it, welded aluminum nuts
to it, blue loctited studs in the nuts, polished the frame and
bolted it to the radiator with stainless steel ny-locks and
stainless washers, with a cushion between the fan and shroud
made of 1/8 thick rubber spacers. I then made a little bracket
to hold 2 40amp Bosch 5-pin relays, and it bolts into the hole
meant for transmission cooler lines (mines a 5-speed), using
a 1/2" fine stainless socket head.
I used a Hypertech 170 degree fan switch, and both fans run
are triggered by it. I also used a Mr. Gasket fail-safe hi-flow
160 degree thermostat and Red Line Water Wetter.
The car now runs right at 160 with the a/c on in traffic in Arizona
in the summertime.
All this on a brand new o.e. sized radiator!
My fan assembly looks very similar to yours-but whatever you
do, don't use those zip-tie fasterners through the radiator.
Old Jun 4, 2005 | 04:15 AM
azvolfan's Avatar
Ok I won't. You guys got me scared now!!!
Which Spal fan did you get?
Old Jun 4, 2005 | 08:06 PM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
Hey I know for a fact that fan in the pic will not fit w/o major mods. I tried to install one on my sister's 84 and it's about 2" too wide. One side hits the steering box, and the other hits the lower hose and cooler lines for the trans. Which is too bad because it looks like a really nice piece.
Old Jun 5, 2005 | 02:59 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
I got a complete used dual fan setup from Hawks for pretty a reasonable price.
Old Jun 7, 2005 | 05:18 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
About the subject of dual fans
My '83 has the fan on the water pump. In an effort to improve summer cooling, I had mounted twin pancakes on the front of the A.C. condenser. Guess what?????????? They caused the car to run hotter, because the electric fans compete in some way with either the air flow from the stock fan, or with the 2-speed fan clutch. Took them off. What gives?
Seth
Red iroc-z 305
Sep 30, 2015 05:22 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
matthew911
Aug 12, 2015 09:38 AM
mx127
Aug 10, 2015 08:13 AM
