horrible vibration with a/c on
Old Aug 13, 2005 | 08:14 AM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
Transmission: stock 700r4
I have an '86 Iroc. At the end of last summer I replaced the a/c compressor , dryer , etc... This year when I try to use my a/c , it works fine either in park , or driving. But, if you come to a stop ( redlight ) the car gets a vibration through the brake pedal and gear shift ( not saying this is the problem , that is just where you can REALLY feel the vibration ) and makes a really odd sound. The belt is as tight as I can get it. The compressor is new , the bracket isn't bent , WTF..
Old Aug 13, 2005 | 10:13 PM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
The belt is not tight enough. Be sure to look at the top bolt on the bracket. I'll bet it is at the end of the slot. You think you have pulled the belt really tight, but you just ran out of room. Try a shorter belt and get it really tight. Then after a few days, you may have to retighten again after the belt streaches.
Old Aug 14, 2005 | 11:49 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Mine does that too at idle with A/C on. I switched from a Cross Fire to a TPI. There was an extra support for the upper A/C bracket that bolted to the Cross Fire intake manifold. The TPI manifold didn't have a place to attach the support. Didn't see any good places to attach a custom support bracket either. For now, I just raised my idle speed a little (on the chip) and the vibration is much less noticeable.
Old Aug 18, 2005 | 11:15 AM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Been fighting this for a while on my truck, vibration just above idle and right at 60 mph, just my luck. Put in a new (not a rebuild) compressor with R134 and correct oil. Noise/vibrationi still there. Really at a loss what causes this. Next step might be a new belt tensioner. Sure is an expensive noise. If you get yours figured out be sure and post.
Old Aug 18, 2005 | 03:44 PM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
I have a new compressor on my iroc. When I get my vibration is with the car in gear and stopped (foot on the brake) the vibration stops when in park or while driving. Sometimes when i am slowing down for a red light the rpm's drop and the car seems like it almost stalls. Again, only with the a/c on. Just put a smaller belt on it and the vibration lessened , but not to any great degree.
Old Aug 21, 2005 | 10:15 AM
Vader's Avatar
Does the compressor have "the brace"?
Attached Thumbnails horrible vibration with a/c on-compressorbrace.jpg
Old Aug 21, 2005 | 07:38 PM
pnutbailey's Avatar
Car: 1986 Iroc-Z28
Engine: stock 305
no, it does not. Although i bet that would almost solve my problem. what year car is that pic from? Also thanks to everyone who took the time to try and help.
Old Aug 29, 2016 | 05:10 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: horrible vibration with a/c on
Do you know where I could get that brace?
Old Aug 29, 2016 | 06:09 AM
Junkyard
Not hard to make a suitable substitute, as well
Old Aug 29, 2016 | 10:56 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
I've had two cars have that exhibit this problem, both were TPI serpentine belt systems.
The first car had headers, no bracket bracing on either side, it vibrated like crazy at certain RPM's
The second car has headers and all the support brackets on both sides, still vibrates but not quite as bad.
The only thing I can attribute the vibration to is both cars have the A.I.R. pump removed and use and alternate belt routing. The long run of belt from the AC compressor to the crank shaft is causing the vibration, I can see it in the belt.
My next step is get an A.I.R. delete pulley and run the stock routing to see if it fixes it.
Old Sep 4, 2016 | 10:54 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
There's another brace that can be added to reduce the vibration. There was a TSB back in the day regarding compressor vibration that listed the P/N's for the "fix".
I believe that pre-'87 TPI cars did not have this added brace.
At the time I found the TSB, the parts were available from the dealership.
I can see if I can dig up the TSB is anyone is interested.
Old Sep 4, 2016 | 11:45 AM
KITT1983's Avatar
please do
Old Sep 5, 2016 | 03:19 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
TSB 86-179 references an inertia ring that is installed onto the compressor.
I think this acts similar to a crankshaft damper. I forgot about this one. IIRC, there was a good reason I had for not installing this. Probably because it was NLA at the dealership.
TSB 88-409-1B and 89-408-1B references the brace and hardware.
Both of these TSB's are essentially identical.
Edit: Forgot to add Figure 1 to TSB's 8x-409-1B.
File Type: pdf
Old Sep 5, 2016 | 05:00 AM
KITT1983's Avatar
thank you
Old Sep 11, 2016 | 05:39 PM
turboguard's Avatar
Car: 1985 Pontiac Firebird Trans Am
Engine: 305 LG4
Transmission: 700R4 Automagic
Axle/Gears: No clue
So I'm also having this problem, I took a video to demonstrate:
Would tightening the belt solve this issue, or could the clutch also need service?
Old Sep 13, 2016 | 11:54 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Tightening the belt should help. But don't overtighten it because it'll strain the compressor and water pump bearings.
Try loosening both the PS and AC belts. Re-tighten the PS belt first and then do the AC belt.
Old Nov 2, 2016 | 05:26 AM
KITT1983's Avatar
bump
Old Nov 2, 2016 | 03:33 PM
1987L69's Avatar
Car: 1984 Z28
Engine: LG4 305/4bbl for now
Transmission: 5-Speed
Axle/Gears: 3.23 Posi
https://gbodyforum.com/threads/flopp...5/#post-477311 I know its for a Monte Carlo SS but it will work on ours, I did it on my 87 SS Monte and I am going to do it to my Z28 here soon
http://www.montecarloss.com/communit...Number=1027488
Old Nov 6, 2016 | 10:51 AM
KITT1983's Avatar
i have v belts i don't think that will work
Old Nov 6, 2016 | 03:47 PM
1987L69's Avatar
Car: 1984 Z28
those are V belts, I just put a mod like that on my 84 Z28 and it works great
Old Nov 6, 2016 | 06:54 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
When my friend installed a ZZ3 in his '68 El Camino he had a terrible a/c belt vibration (very long distance between the W/P and compressor).
He took the entire belt idler assembly off a VW Jetta and fab'ed up his own brackets as in the previous post.
Old Nov 6, 2016 | 07:00 PM
1987L69's Avatar
Car: 1984 Z28
It works great!
Old Apr 4, 2017 | 12:30 AM
stahrman0612's Avatar
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
ac clutch belt - YouTube
Mine is doing the exact same thing as yours. It's normal until I turn on the AC. I've tried tightening it without over tightening, but still jumps around like yours in the video? My mechanic said it was normal on these year cars?? Maybe to a certain extent, but I don't think this much moving is normal??? If you find a way to fix it, be sure to post your solution. Thanks!!
Old Apr 14, 2017 | 05:20 AM
KITT1983's Avatar
any updates
Old Jul 4, 2019 | 07:09 PM
KITT1983's Avatar
https://nemigaparts.com/cat_spares/e...f/09/mf09-013/
just bought. GM PART NUMBER "10046001" after searching forever
Old Jul 4, 2019 | 07:57 PM
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
Did it fix the problem?
Old Jul 10, 2019 | 08:36 PM
KITT1983's Avatar
the part just arrived
Old Aug 11, 2019 | 06:16 PM
KITT1983's Avatar
yes
Old Aug 11, 2019 | 06:22 PM
KITT1983's Avatar
yes
Old Aug 19, 2022 | 09:35 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
I had and still have that issue but not really bad before putting a pulley on the upper AC bracket. Still vibrates but not as bad. I will be extending the pulley though with a thingy-ma-jig that I made.
Old Apr 23, 2023 | 06:53 PM
Update on my vibration. I was missing a nut behind the PS Pump. No more vibration!!! Granted that I have an 86 TPI. But the stud behind the pump had no nut. The stud protruded behind one of the brackets. All good now.
Old Apr 24, 2023 | 06:08 PM
Yup, that would certainly make a difference.
RED85TPI
Mar 29, 2015 01:55 PM
soileaujp
Jul 5, 2006 03:23 PM
Damon
Jul 9, 2004 09:54 PM
fourspeed
Aug 27, 2002 08:17 PM
