Water pump ?
Old Aug 13, 2005 | 12:11 PM
sellmanb's Avatar
Car: '86 Berlinetta
Water pump ?
I have searched and couldnt find the answer (though I'm sure I'm just looking in all the wrong places ).
I want to get an aftermarket water pump....
I have the original 1986 LG4 V-belts setup....
is this clockwise, or CCW rotation?
do I need a long snout, or a short snout?
Thanks!
(I'm looking to go with a Stewart pump)
Old Aug 13, 2005 | 12:23 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Clockwise, long.
Old Aug 14, 2005 | 12:01 AM
rlrepitman's Avatar
Car: 1987 Camaro SC
Engine: LG4 305
Transmission: TH700R4
Clockwise rotation and long snout.
Old Aug 21, 2005 | 12:51 AM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
I have an 86 camaro, with a swapped engine. How do I tell what replacement water pump I need? I'm thinking I need a long snout.
Old Aug 22, 2005 | 03:50 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
Pump
Hi,
Are you running a full serpentine belt system as in
the 88 and up cars??
Later
jaykar
Old Aug 24, 2005 | 01:40 AM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
I am in the same situation as you, what stage Stewart pump are you going to go with?
Old Aug 24, 2005 | 12:56 PM
faulball67's Avatar
Car: 1986 IROC Z28
Engine: 350 carbed
Transmission: TH350
Axle/Gears: 3.43
mine has both a v belt and a 5 groove serpentine pulley on it. The water pump and alternator run off the serpentine crank pulley and the power steering pump runs off of a v belt.
Old Aug 24, 2005 | 01:54 PM
jaykar's Avatar
Hi,
Water pump V belt clockwise. Long style.
Full serpentine counterclock. Long style.
My 87 Iroc was the same and switched over to 89 configuration
and had to get new PS pump,Alt and WP. Went with the AC
delete bracket and Serp pulley.
Later
jaykar
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
