Water pump belt wheel loose
Old Mar 16, 2007 | 12:51 PM
Guest
Guest
Posts: n/a
Hi,
I have a 1984 Trans Am V8 with clutch fan.
The wheel on the water pump on that the belts run is loose.
It moves up/down/left/right. What could be the problem?
I do not know how these pumps are built. Are there bearings
inside and they are maybe worn? How can I identify the cause?
And what is the solution? Replacing the pump?
Please find attached 2 pictures. Not the fan is loose on that big wheel
but the big wheel itself moves relative on the pump and of course it
gives noise.
Thank you,
Laszlo
Old Mar 16, 2007 | 12:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It sounds like the bushings inside the pump are wearing out. If you remove the belts and the 4 nuts holding the fan to the pulley, you can remove the pulley from the pump, and check the pump shaft for play. The best solution would be to replace the pump.
Old Mar 16, 2007 | 03:11 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yep time for a new pump
it happens, pumps are dirt cheap and simple to swap
good luck
Old Mar 17, 2007 | 04:40 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
yea, most likely a bum pump.
Not to worry though, like said above they are cheap and easy to replace!
Old Mar 20, 2007 | 07:46 PM
Guest
Guest
Posts: n/a
Cannot remove water pump
Hi,
Important question: do I have to remove the power steering wheel pump
to be able to remove the water pump??? I removed everything now but
there is a big bracket or what which holds the power steering pump and
this is bolted to the water pump. I remove the bolt but the bracket is
still in front of the water pump. Do I have to remove that bracket?
It is bolted with 4-5 bolts to the engine and other parts there.
If it is not necessary then I do not want to touch the steering pump.
Thank you,
Laszlo
Old Mar 20, 2007 | 07:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Water pump belt wheel loose
You'll have to remove the alternator and power steering pump brackets to remove the water pump. You don't need to disconnect the power steering hoses though. Just unbolt the brackets and move the steering pump to the side.
Old Mar 20, 2007 | 07:57 PM
Guest
Guest
Posts: n/a
Thank you!
At the moment I can not see any possibility for adjusting the belt
of the steering pump. Am I right? I do not understand the whole
logic there. I can not see a pivot bolt and so on. If I unbolt the
bracket and then bolt it again then the belt is adjuted again?
I do not understand.
2 bolts of that bracket are behind the wheel on the steering pump.
Can I just take them off? They are between the wheel where the belt is
running and something else maybe engine. Or should I first remove that
wheel from the steering pump?
Laszlo
Old Mar 20, 2007 | 10:57 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The bolts you're looking at are for mounting the power steering pump to the bracket. You don't want to touch those. There are three bolts mounting the power steering bracket to the engine. One on the water pump, one into the head, and one into the bracket on the exhaust manifold. Those are the ones you want to take off.
Old Mar 21, 2007 | 01:48 AM
Guest
Guest
Posts: n/a
OK, I understand. But before I unbolt the bracket first I should
loosen the belt, am I right? Where can I do it? I was looking for
two bolts but I could not find them. The pivot bolt and the other one.
Thank you,
Laszlo
Old Mar 21, 2007 | 10:58 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The pivot bolt is the one in the head. The bracket slides on the other two.
Old May 1, 2007 | 08:50 AM
xbcrguy182x's Avatar
There will be one bult behind the p/s pump. Loosen that and you can slide it away. It took me literally hours to figure that out lol
Old May 1, 2007 | 09:11 AM
Guest
Guest
Posts: n/a
Hi,
I could replace the water pump without removing the power
steering pump. Now everything works fine an´d it does not
leaking.
Laszlo
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
