any have? vacuum schematics for a/c?
Old May 8, 2007 | 09:54 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok i have a 92 camaro that had a 305tbi. and when i did an ls1/t56 swap i cut the vacuum lines coming form the fire wall to the intake for the a/c vents. well i need to get the vents out of default mod(defrost). and back to working normally. anyone have the vacuum line diagram from the control head to the intake manifold?
Old May 9, 2007 | 12:24 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: any have? vacuum schematics for a/c?
Take a look in this thread. You will need to scroll down a few messages until you find the one with the daigram attached. You can also use the diagram attached here.
https://www.thirdgen.org/forums/inte...r+vaccum+lines
You may need to right click on this diagram and "Save As' to your computer and then rotate it in some picture viewing software. Notet that the Vac. Tank is in the engine compartment and the "dash" in this diagram is actually the firewall.
Dave
Attached Thumbnails any have? vacuum schematics for a/c?-hvac-vaccum-diagram.jpg
Old May 9, 2007 | 10:11 AM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
dude you are the man! thanks a bunch
Old May 18, 2007 | 09:32 PM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
how about the full vacuum diagram for the 84 Z28??
Old May 18, 2007 | 10:47 PM
have you tried the function yet . I don't have a full vacuum diagram for the 84 year, but I think you will find one if you search. Yuo might try limiting yur search to the TECH/General Engine board. There may also be one further back in this board.
Also have you look on the radiatior fan shround, under the hood. There should be one there, unless it has been removed.
Dave
Old May 18, 2007 | 10:51 PM
C.M.Jones's Avatar
fan shroud no originally from my car and yes I did use the search function maybe not hard enough
Old May 18, 2007 | 11:10 PM
82CAMAROBBC's Avatar
Car: 1982 Camaro
Engine: 454
Transmission: TH350
Axle/Gears: 410
you can get just about any schematic from the autozone web site.
Old May 19, 2007 | 01:01 AM
C.M.
Search using vacuum+diagram for the last six months in all boards. You will get about 37 hits, some with diagrams. However, I did not see a diagram for an 84 Z28 specifically. Or you could take a look at the autozone web site, as mentioned above, and see what they have.
Dave
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
thunder57
Nov 7, 2015 02:28 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
