what do you think? is it working???
Old Jun 7, 2007 | 12:23 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
hey guys whats up, i have a question, is my airdam in the right position? shouldent it be in the other direction?
Old Jun 7, 2007 | 12:26 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Re: what do you think? is it working???
Ummmmmm, shouldnt the air dam be on the "Front" of the vehical???
Old Jun 7, 2007 | 12:28 AM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
dang, i forgot to put in pic, well here it is.
Old Jun 7, 2007 | 01:15 AM
jccaclimber's Avatar
Car: 1991 RS Camaro
Engine: 350 0.060" over
Its in right. Those supportng ribs are on the back. It restricts air so that the high pressure section shoves it through the radiator. It is NOT a scoop which is what it would be if you reversed it. It would work better but at the same time it would be far more likely to break when you hit and edge. In this configuration it merely bends back.
Old Jun 7, 2007 | 02:20 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
It looks a bit beat up, but it's general purpose is served as stated above and it is bolted on correctly. It should have a slight forward rake if it was in mint condition, but I doubt that changes the performance much.
Old Jun 7, 2007 | 07:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if you think that one looks beat up, when i changed the original one off my car i found it to be 2" shorter that the new one, it was totally worn away.
Old Jun 7, 2007 | 09:30 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
hey thanks for your reply. 1 more question, what is this
Old Jun 8, 2007 | 04:37 PM
Car: 1991 RS Camaro
Where do the lines go? Its a cooling radiator for something, and I don't think its an air cooler. An aftermarket oil cooler perhaps? Mine doesn't have one and I've never seen it before.
Old Jun 8, 2007 | 11:16 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
My first guess would be a tranny cooler though you're supposed to mount it in front of the radiator... who knows though... tracing the line is the best way to find out.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
