ENGINE OVER HEATING PLEASE HELP!!!
Old Nov 10, 2007 | 11:40 PM
85camarojunkie's Avatar
Car: Camaro coupe
Bought new camaro and electric fan is not kicking on while im driving causing my car to over heat, replaced single with dual and they worked for a lil bit then they only started working when i turned on the a/c.
Any Advice?
Old Nov 11, 2007 | 12:05 AM
85irocz355tpi's Avatar
Car: 85 IROC-Z
Engine: 355 TPI
Transmission: 700R4w/Shift Kit
Axle/Gears: B/W 9 Bolt-3.45
Re: ENGINE OVER HEATING PLEASE HELP!!!
Did You Check The Fan Relay. It might also be a short or the temp sensor. Last Thing to check is the computer. If all else fails try hot wiring the fans to something that comes on only when you turn the key on. Nice car by the way.
Old Nov 11, 2007 | 12:54 AM
engineerbrad's Avatar
Car: 2004 2500HD 4x4 Chevy
Engine: 6.0L
Transmission: Automatic
Axle/Gears: 4.10
Did you ever get around to checking the fan relays?
1) Do relays have 12vdc power?
2) Is temp switch closed when engine is hot? (if installed)
3) Do fans have good ground?
4) Does temp switch have 12vdc power?
Not sure how the fans could be impacted by the A/C system. Will need more details to help with that.
Old Nov 14, 2007 | 07:54 PM
fast14cars's Avatar
i would check the temp sensor. mine was stuck on -40 degrees causing the computer to think the engine was cold and thus not allowing the fan to come on. a quick fix is wiring the fan directly to the battery with some kind of switch. i did this untill i got it fixed and it worked fine.
Old Nov 14, 2007 | 08:00 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Could be a bad fan switch.
Old Nov 15, 2007 | 05:00 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
I`m assuming if your car had a single fan and you hooked up dual fans that you spliced the fan wires together and connected them to the existing fan wire so they both come on at the same time? On cars that come stock with dual fans, the secondary fan comes on when the air cond. is turned on. It sounds like you may need a new fan switch. I`m not sure on single fan cars if the fan is controlled by the ECM or thermal fan switch. I sent you a message about wiring diagrams, let me know.
Old Nov 15, 2007 | 05:05 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
if it was the relay then it would never turn on even w/ AC. Most likely the fan switch. the switch that tells the ECM what temp it is and then the
ECM turns the fan on.
Old Nov 15, 2007 | 05:16 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
w/ ryan... check the coolant temp sensor, and fan switch for a short.
Old Nov 15, 2007 | 06:42 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
The fan is controlled by a fan switch in single fan cars, at least it is in my 92.
Old Nov 16, 2007 | 02:34 PM
Car: Camaro coupe
cool, i know alot about older motors but this TBI crap is just different to me this is the 2nd one ive owned that was. Thanks alot. i'm just going to start with the first then keep going down your guys list. and engineerbrad thats an old camaro thing. if your getting hot turn the a/c even if it don't work, kicks fans on
Old Nov 18, 2007 | 09:25 AM
frirebird952's Avatar
Car: 86 ta ws6 silver and gun metal
Engine: 305 fi lb9 eng code f
Transmission: 700 r4 with shift kit
Axle/Gears: lim slip not sure gears
if i remember right the cooling fan relay is controlled by the temp sensor and the ac switch check all wires at relay but its prob the temp sensor but i have seen the relay only have power on the ac side i guess if all else fails put it on the switch it will run as long as its on
mustangman65_79
Sep 1, 2015 03:51 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
