Big Issue!
Old Dec 8, 2010 | 02:33 PM
Willishxc's Avatar
Car: 1985 Iroc-z Camaro
Engine: 350 V8
Big Issue!
Ok, so i bought a 1985 camaro a month or two back, great condition, rebuilt engine, and shaved engine bay. Only problem is that the guy had removed anything and everything to do with the heater out of the engine. Does anyone know where i can buy a whole new heater assembly? or i heard talk about an electric heater system? any help would be appreciated.
Old Dec 8, 2010 | 07:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Big Issue!
You mentioned shaved - has he removed the heater core and filled in the 2 firewall holes for it? If so, you'll have to redrill those, and not only get the heater box/blower motor for the engine bay, but you might need the box under the dash that holds the heater core in place on the inside. Better crawl up under that dash and see what's there first.
Old Dec 8, 2010 | 07:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Big Issue!
there are elect. heaters made for use on 12v. systems . they are used in construction/heavy equip. ect. . nothing you would want to use in a 3rd gen. . DO NOT TRY THEM . good luck .
Old Dec 9, 2010 | 10:28 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Big Issue!
If it's all gone it may be easier to move to Florida if you want to be warm!
Old Dec 11, 2010 | 04:04 PM
Willishxc's Avatar
Engine: 350 V8
Re: Big Issue!
sorry it took so long to reply, the car isn't up at school with me. But the two firewall holes are still there, he must have either redrilled them or not covered them. Also i'm pretty sure the box under the dash is still there.
Old Dec 11, 2010 | 08:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Big Issue!
you need to figure out whats there and what isnt. If the heater core is still there and just not hooked up, its simply a matter of getting a proper heater box and blower motor, wiring it up, and hooking the core back up. If its all hacked out, you may have to get a new heater core.
you may also have to replace the heater control wiring and vacume lines if htey are gone too, but again, you need to know what you have/dont have first
Old Dec 11, 2010 | 08:26 PM
Willishxc's Avatar
Engine: 350 V8
Re: Big Issue!
ok thanks. well i'm going to try and go out and figure all this out tomorrow, i just have limited time right now with finals and all, and limited knowledge but thats why i come to you guys
Old Jan 4, 2011 | 10:11 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Big Issue!
I've got the service manual for mine, with adequate diagrams of
all components. I'm not gonna clog up this thread, but if you need
something like that, PM me, & I'll scan the pages, and send as jpegs.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
greenyone
Sep 2, 2015 03:39 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
Leggman1
Aug 6, 2015 04:15 AM
