Heater core inlet/outlet question
Old Sep 19, 2011 | 12:28 PM
meso5012's Avatar
Car: '04 Ram Hemi & '86 Camaro
Engine: 327 bored to 355
Axle/Gears: 323 posi
Is the smaller hose connection(on left) the inlet and the larger(on right) the outlet on my '86 camaro?
Old Sep 19, 2011 | 12:40 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Heater core inlet/outlet question
Smaller one is the inlet.
Old Sep 19, 2011 | 01:25 PM
meso5012's Avatar
Thank you!!!
Old Sep 20, 2011 | 12:51 PM
ray1989's Avatar
Engine: 350 40 over
can the outlet only go into the manifold? im trying to run it back in the rad and it wont circulate
Old Sep 20, 2011 | 12:54 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
When coolant leaves the HC, it should never go back to the manifold. It should go to the water pump, radiator, or lower radiator hose.
Old Sep 20, 2011 | 01:21 PM
ray1989's Avatar
Engine: 350 40 over
my inlet is the water pump and outlet is under the rad cap but it wont flow through the heater core. any ideas? ( heater core is clear )
Old Sep 20, 2011 | 01:40 PM
-AO-'s Avatar
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Coolant should leave the manifold, go to HC, then return to water pump or radiator.
Old Sep 20, 2011 | 02:06 PM
ray1989's Avatar
Engine: 350 40 over
o ok i see know thank you
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
